Thinking About New Wheels - Opinions/Advice?
They also sent a pic with red wheels for fitment comparison that looks pretty good (fitment I mean, lol). Wheels in the pic are 20's, but it still gives a good view of what the 19's will look like.
So they are recommending:
Front: 9.5" with +35 offset and claim it will push the wheel out 8mm (this is what the spec in the picture is)
Rear: 10.5" with +50 and claim this will push out the wheel 14mm relative to stock.
They said the 265's and 305's will be fine.
These are the specs in this picture that looks pretty good to me:
This is a picture of the wheels I am going for (EH172 in Brushed Dark Black)
Attachment 439775
If you are gonna pull the trigger on 305's and wanna be as flush as you can be.... do ET47/8. You will be fine.
They also machine their lug holes for their 60degree bolts, but will machine them as stock if you want to keep the stock bolts (which is what I'm thinking).
Good news about the lugs too as I had to buy more on one occasion.
Looking forward to the install!
So BC Forged is telling me they can't 100% guarantee that the PS4S tires in a 265/35/19 on the new 9-1/2 wide rim will not have any rubbing issues. They did confirm what was mentioned above about Michelins sitting more square than most tires and therefore need slightly more clearances.
He also said he doesn't think it will rub with this setup but can't guarantee it. BTW the above proposed setup is with the +35 offset. He said there really is nowhere to go inward or outward. I mentioned that I run this by some of you guys running the 265's on the front. Any of you have 265 PS4S's on your front? Also, as a reminder, I am running at stock height with no suspension mods.
Thanks a lot
When it comes to actual performance, what matters for grip is the tire compound, not the width. 285 section width Kumho Ecsta PS91 will out perform 315 section width Conti ExtremeContacts without necessarily assuming all of the shortfalls of installing super wide tires. The idea is to install only what you're going to adequately use. This is why I scoff at many many street cars with flared fenders running wheels half again wider than stock with tires 5 sizes larger than they came with. These cars are miserable to drive, handle worse on the road, and are slower than they would be with setups that fit within the stock fenders.
At least from a performance perspective, what matters for grip is the tire compound, not the width. 285 section width Kumho Ecsta PS91 will out perform 305 section width Conti ExtremeContacts without necessarily assuming all of the shortfalls of installing super wide tires. The idea is to install only what you're going to adequately use. This is why I scoff at many many street cars with flared fenders running wheels half again wider than stock with tires 5 sizes larger than they came with. These cars are miserable to drive, handle worse on the road, and are slower than they would be with setups that fit within the stock fenders.
Please, anybody that can confirm that this will be OK based on experience.
Thanks a lot
That was the only rubbing I got at stock ride height with 275/35/19. That was up against the front of the fender liner. Also, at ET32 (3mm spacer on ET35 wheel). While I have no personal experience with your proposed set up, I can tell you that even with a tire 10mm wider I was able to go 3mm further out without rubbing against the fender. I am pretty sure a 265 "runs wide PS4S" should be fine.
What tire in 265/35/19 are they "guaranteeing fitment" with? You could find the exact shoulder to shoulder measurement of said tire and compare to that of the PS4S.
So you might go 265/30 tires to fit vs 265/35 tires.
If I go with 30 vs 35 in the front isn't my outside diameter getting smaller and thus would affect my speedo and such? Also, thinking it might be a rougher ride?
According to tiresize.com calculator the 265/30 is exactly 1 full inch smaller diameter than the 265/35. I would think this is enough to throw things like speedo and odometer off.
