Switch to winters time
Old Oct 27, 2019 | 07:44 PM
joonesthesia's Avatar
'16 E63
For us in the north, it's just about winter wheels time.
Ever since the michelin pilot alpins, I honestly don't feel theres that much of a sacrifice anymore. It's absolutely incredible.
It's also a good chance to take off the summers and clean everything because holy brakedust. I joke that somewhere under there, there's a wheel. I find off the shelf Vim to work very very well. Cuts through and clean just after a few wipes.
On a subjective note, I use the pre-facelift 19" e63 oem wheels as winters and they're significantly heavier than my oem summers even though they're both forged construction. Doubt tires would make that much difference, 295/30 vs 275/40 rears.
After a morning of interior cleaning - 9:1 distilled water and rubbing alcohol and subsequent leather conditioner and wheel cleaning/swapping a nice moment in the sauna for the back/neck and it's football time!
Old Oct 27, 2019 | 09:23 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Originally Posted by joonesthesia
For us in the north, it's just about winter wheels time.!
Ugh. Yeah, I can't believe it. We're due for some snow here in WI this week.
Old Oct 27, 2019 | 11:58 PM
SAMzE63s's Avatar
E63s
Where about are you? I just bought my winter tires today.
285/30 and 245/35 alpine PA4
Old Oct 28, 2019 | 11:18 AM
rlevy's Avatar
2014 E63S Wagon 2017 BMW X5 3.5i 2012 BMW X5 3.0D and 2000 Porsche 911
Yup. I live in Jackson Wyoming and just got my Alpin's on. This is my first winter with this '14 E63s Wagon so we'll see how it does. That front is awfully low. May be I'll just start a plowing company. LOL
Old Oct 28, 2019 | 05:47 PM
'16 E63
Up in eastern ontario canada. it's been a very pleasant fall thus far. that'll change abruptly mid week with rain mixed with snow on the way!
rlevy, your wagon will power through anything. With the alpins on one trip I went through all the following;
-20C, snow, blizzard, fresh snow, packed snow, freezing rain, ice pellets. The car with the alpins handled it like nothing else.
Old Nov 16, 2019 | 08:28 PM
SLe63's Avatar
E63
So this is my first winter. And Im thinking of using the 19" OEM wheels. I have a 2011. TR is suggesting 255/35 all around?
Old Nov 17, 2019 | 12:20 AM
I.T. Guy's Avatar
2023 E63S Wagon
I did this on all 4
Michelin - Pilot Alpin PA4 - P255/35R19 XL 96V BSW
Replika Wheels R157 Black wheel 19X8.5, 5x112, 66.5, 32 offset
Old Nov 17, 2019 | 01:17 AM
SAMzE63s's Avatar
E63s
I’m north Alberta Canada. So I feel your pain ahahaha
Old Nov 17, 2019 | 09:55 AM
amgwagonne's Avatar
2014 E63S Wagon
If you get two sets of OEM fronts, that'll work and will have the same outside spacing on the rear. If you get aftermarket with 255 square setup, just make sure they're the same offset (32) or as close as possible, erring on the side of a smaller offset to prevent the wheels from being too "sunken in."
Edit: Also, FWIW, I'm running the same staggered OEM setup (F:255, R:285) for winters and it's great.
Old Nov 17, 2019 | 10:02 AM
'16 E63
I think it makes little difference with either square or staggered. At least to me in the conditions where I am.
SLe - your car will also accept 18" rims and it'll clear the brakes no problem. I had 18"s for winters on my previous E63 to fit tires with taller sidewalls. Used 255/40/18, square setup, OEM 18" rims.
On the 16 wagon I am using a staggered setup due to tire availability when I first got it - 245/40/19 and 275/35/19 Pilot Alpin 5's. I like to go one size narrow and one size taller.
Samz: Edmonton?
Old Nov 17, 2019 | 07:16 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Originally Posted by I.T. Guy
I did this on all 4
Did the same wheel set up, and tire size except with Nokian R3s.
Amazing setup.
Old Nov 17, 2019 | 07:36 PM
SAMzE63s's Avatar
E63s
Samz: Edmonton?
It’ll make a very small difference running 255/35/19 on your staggered stock wheels.
I was about to run 255/35/19 on all 4 corners on my 14 but found a set of new 285/30 245/35 for 800 bucks. Couldn’t say no.
Yessir, I’m commute between Edmonton an Fort Mcmurray
Old Nov 18, 2019 | 09:20 AM
rlevy's Avatar
I have a 2014 E63s wagon. While I still can't attest to the Pilot Alpin's winter snow capability (eventually it always shows up), after a spirited drive that took me over two mountain passes yesterday, I can say that they perform extraordinarily well on dry pavement, better than any snow tire I have ever experienced (and I have tried lots).
Old Nov 18, 2019 | 11:08 PM
signes's Avatar
E90 M3
Ran the PA4s in 255/35 and 285/30 and it was amazing in Colorado mountains.
Old Nov 20, 2019 | 03:57 PM
Richbot's Avatar
'26 E53 | '08 E90M
I had to put them on in frickin' early-November in STL. This thing is a handful below 30 degrees on summer tires even with the AWD, and then we had a forecast for 10 degrees out and an ice/snow storm, so I pulled the trigger. Was the right call, it was nasty for early Movember in STL
I think the PA4's might have more grip than the almost-dead Conti 5P's on the front of my summer set. Can't wait to not put those on next spring, got my year out of them, time to die MFers. Other than mroe highway noise, the PA4's are almost year-round worthy if you don't mind burning through them fast
The Rial M10's are still a nice looking wheel for a dedicated winter set. Also, pleasant surprise, the car still remembered the TPMS from last time they were on thec ar, didn't even have to do a re-learn
For what it's worth, our square 255/35-19 on 19x8.5 ET32-ish (can't recall what size Tire Rack sells) wheels PA4 set doesn't make the car handle weird. THere is just soooooo much understeer built into the chassis. I have to try really hard to break the rear end loose, TC has to be off, and you have to really ape the steering and throttle. This car gives you the tommy lee jones looking over the top of his glasses in the fugitive look when you try to hustle it in a corner - son just wait until you can see the track-out point and then we can go
Old Nov 20, 2019 | 05:31 PM
'16 E63
like the other owner opinions, I am very very impressed with the michelin alpin's. Such good grip in cold dry and snow/ice/slush/wet, always feels sure footed.
Old Nov 21, 2019 | 08:54 PM
SLe63's Avatar
E63
on 19s? what tires did you go with?
TIA
Old Nov 21, 2019 | 09:01 PM
SLe63's Avatar
E63
I should be fine on pilot a4s right? this thing is rwd.
Old Nov 22, 2019 | 09:01 AM
FastWgn's Avatar
2016 E63 Wagon
Old thread
There is n old thread on this - see my results:
MB World initial setup
MB world snows discussion - miles later
Only thin to add is that the Replika wheels held up well all season. Hit some potholes and are still straight.
Old Jul 24, 2020 | 02:15 PM
Wilson Lau's Avatar
2011 E63
Can I get more pictures of your winter wheel setup please? I would like to know how it truly looks like. It looks like your 245-40-19 and 275-35-19 are looking quite good! My email is wilson6290@gmail.com.
Old Jul 24, 2020 | 02:50 PM
cotmfk's Avatar
On the shoulder
It's almost 100 degrees outside here!
:sweat:
Old Sep 27, 2020 | 10:05 AM
'16 E63
sorry about the late late replies. It's getting cold here now! Below freezing overnights here and there. Only 4~6weeks more and I'll be on winters.
Wilson, there is a post I made here showing clearance. it's close but it's fine. i haven't gotten any marks or scratches in the wheel well liners.
https://mbworld.org/forums/w212-amg/...revisited.html
they are 245/40/19 and 275/35/19 alpin 5s.
Old Sep 27, 2020 | 12:29 PM
nota_amg's Avatar
2013 SL550 BiTurbo
Winter? What's a Winter??? Here in Texas, we just have "Summer" and "not-quite-summer"
