Ignition coil Cyl 5
Old Jan 30, 2020 | 06:37 PM
wseikow's Avatar
E63S 2016 [W212 ] :::: E55 2002 [W210 ] [31k miles] ::: TARGA4S 2007 [ 997.1 ]
Ignition coil Cyl 5
Car felt like it was going to stall when given gas, slow acceleration. Gave harder push and seemed better.
Then later that day, same thing and check engine cam on.
Brought to dealer and they say they replaced ignition coil Cyl 5.
haven't picked up vehicle yet. Anything special I should tell the dealership, or need to know moving forward?
Is it covered on extended warranty? 2016 E63
Also, mentioned this to a friend... he asked if these work in "Pairs"
Thx for the feedback
Old Jan 30, 2020 | 08:08 PM
amgwagonne's Avatar
2014 E63S Wagon
Coils are indeed covered by CPO warranty, which is what I assume you're referring to? No, you don't need to do "pairs," You just replace whichever one is failing.
There's nothing you really need to do at this point. I do recommend getting yourself a cheap BT OBD reader so you can pull the codes yourself with your phone. That way, you'd understand better why the dealer did what they did. In this case, it's probably documented on your work papers.
Old Jan 31, 2020 | 01:26 AM
PeterUbers's Avatar
Coil packs are a weak point on this engine
how many miles on the car and are you tuned?
https://mbworld.org/forums/w212-amg/...-w212-amg.html
Old Jan 31, 2020 | 07:00 AM
wseikow's Avatar
53000KM.
No tune.
Old Jan 31, 2020 | 07:56 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
If one goes a second will follow soon
I would ask if possible to replace them all...Its a stretch ..then put some fresh plugs...
Does I had looked into aftermarket coils but no look,I would think MSD would make a stock replacement.
That number 5 plug probably has built up from not firing.
Old Jan 31, 2020 | 10:15 PM
PeterUbers's Avatar
excellent point
