Several Coil Failures after Tune
Old Mar 13, 2020 | 07:06 PM
arcticfox's Avatar
2020 E63S
Hi all,
Car -- 2014 E63S
I installed a tune about two month ago and have had three coils fail since (with no coil failures previously). My car only has 18,xxx miles on it!
#1 coil failed -- replaced with OEM coil
A couple weeks later, #8 coil failed. Replaced with OEM coil and ordered 6 more (to replace the rest, which I have yet to do).
Last night #1 coil failed AGAIN (this is a "new" OEM coil that was only in there about a month).
These coil all failed under WOT. Restarting the car seems to work, but as soon as there is about 50% load, they stop working again.
The only things different from a couple months ago are: time, mileage, and the installation of a tune.
Time: Only about 2 months
Mileage: Not much over 1,000 miles
Tune: Hmmmm (no issues with stock....coils failing about a month after installation)
I am wondering if the tune would place additional strain on the coils? It sort of makes sense....higher boost + higher loads = more demand from the coil for spark output.
On that assumption, I have NOT gaped my plugs down as suggested by some on the board. I suppose a larger gap + increase load/demand may equal too much to ask from the coils. Thoughts???? Maybe tightening the gap will make it easier on the coils??
I have new plugs ready to install (with tighter gaps) and will order the one extra coil I need to swap them all out and will probably do so this weekend (sans the extra one coil that I now don't have).
I am curious of any of you had coils fail after the installation of a tune, and if so, were you running stock plug gap or reduced?
Thanks...just trying to narrow this down.
Old Mar 14, 2020 | 08:00 AM
Ncbimma's Avatar
E63S
Same thing happened to me on my X5M when I went stg2 tune. I was able to defeat the limp modes with 1) all new high performance coilpacks 2) 1 step colder plugs gapped down and the car never limped again. I've yet to explore a tune on my '14 AMG S.
Good luck
Old Mar 14, 2020 | 03:53 PM
arcticfox's Avatar
2020 E63S
Thanks. That's an interesting coincidence.....
Old Mar 14, 2020 | 04:50 PM
Magno's Avatar
2013 E63 Estate
Are you still on original plugs? Wondering if you are chasing coil packs when it is actually your plugs?
Old Mar 14, 2020 | 06:25 PM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
I would gap down and go one stage colder asap.
Old Mar 14, 2020 | 09:26 PM
try m3's Avatar
Top Answer: 1
M3, E55, cls63
Not sure if it’s coils sounds more like plugs. I’m tuned with a stage 2 tune and 2 step colder plugs 114k miles on original coils.
Old Mar 15, 2020 | 07:02 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
I have had both AMS and Eurocharged tunes on my 2015. I did have misfires on and off until I discovered that Shell gas is crap. No issues since switching to Chevron. And it's only 91. I am running 3.0 0-60 and 7.2 0-100 and 11.1 1/4 mile on the 91. I HAVE YET TO FAIL A COIL. I have logged somewhere around 15k miles on the tunes as well.
Try switching gas for a starter. It's a lot bigger deal than people realize. And how do you know that the issue is actually the coils? Are you going off trouble codes? If you read "misfire on #1 cylinder" or the like, that can definitely be gas. Not coils.
Just some thoughts
Old Mar 15, 2020 | 07:04 PM
Vrodman's Avatar
BTW,
I am also in Cali. San Jose area. Shell here is garbage. I have proven it!
Old Mar 15, 2020 | 07:24 PM
Shell logs more knock retard than Costco gas at least from the station I pull from. I do not believe Shell would cause misfires but maybe ignition retard. I would install new (colder) plugs since it should be done anyway and gap down to roughly .024-.026 or so.
Old Mar 15, 2020 | 11:06 PM
arcticfox's Avatar
2020 E63S
****...never thought of fuel! LOL
Yes, i am assuming coils as I was getting the misfire code. Being as I only have 18,xxx miles, I figured it wouldn't be plugs....
To throw caution to the wind, I replaced all plugs today and gaped them to .024 I also replaced 7 coils (waiting for one more to come).
I took the car out and had the same issues....misfires in two cyls, etc.
I reinstalled the stock tune and IT RUNS FINE. lol I drove the **** out of it and it only hiccuped once under WOT (I felt it cut out for a split second once).
I was thinking fuel pressure, not fuel quality. I will run it around a bit and drain this tank, then fill up with Chevron. After that, i will reinstall the tune and see if it returns. It could be entirely possible this is due to a bag tank of gas! I never thought of that. I last filled with 76....but will try to swap to chevron and see how it goes. Thanks for the advice!
Just some thoughts
Old Mar 16, 2020 | 01:04 PM
Vrodman's Avatar
I have proven that Shell, at least here in Cali, causes misfires on our tuned engines. It's not a guess. I have been planning to post an entire thread with all of my findings and how I proved it. Just have not gotten around to it yet. Peterubers and Jvakos both know about my testing in detail and agree. Unfortunately, they are in Chicago area and don't get Chevron. Again, this is not speculation. I can also tell you that Shell's Winter Blend gas here in Cali is even worse. If the OP got misfires using Shell it's no surprise AT ALL.
Additionally, I still have all stock coils and plugs gapped to original specs. No misfires since I left Shell. You saw the times I am running on my EC Stage II tune.
Old Mar 16, 2020 | 01:08 PM
I have not played much with Mercedes. What is everyone using to log with? I assume you attribute the misfires to the type of detergents Shell uses?
Old Mar 16, 2020 | 01:10 PM
Vrodman's Avatar
Yup! drain that tank on your stock ECU and then fill up with Chevron. Drive it about 5 to 10 miles and swap ECU to the tuned one. Since I do not know who your tuner is, I can't guarantee anything. But I suspect your misfires will be gone, even without touching plug gaps. You can also try adding 5 gallons or so of 101 race fuel to your tank if you still get them. a few 76 stations have it (~$8/gallon) We have one about 3 miles away from my house.
Good luck, and PLEASE report back with your results. I can include your data when I finally make my post on gas quality.
Old Mar 16, 2020 | 01:16 PM
Vrodman's Avatar
detergents and/or their winter blend that has apx 10% less energy in it, which does go straight to octane. Do not be fooled by the octane sticker at the pump. There is a window of uncertainty on those numbers. Based on rough estimates and research on the winter blend it looks like our 91 octane may only be as high as 89.
Two years in a row I discovered misfires using 2 different tuners, AMS and EC, right after the stations here switched to winter blend. Had I figured it out earlier I would have kept my AMS tune. Again, I will post all of this in the near future.
Old Mar 16, 2020 | 02:11 PM
This would be new news to me. I have not found lower octane or a lower ability to prevent pre ignition to cause an actual misfire. I could see bad gas, old gas etc. but not additives from Shell causing an actual mis. I look forward to your findings. Will you be posting logs as well?
Old Mar 17, 2020 | 09:51 AM
Savage212's Avatar
2014 E63 AMG wagon
It is down right shocking how fuel quality effects my tuned M157. Having a few tuned cars, none has been as sensitive to fuel quality as this one. So much to the point I put some 100 in almost every tank just to not worry.
Old Mar 17, 2020 | 05:43 PM
Vrodman's Avatar
Are you saying that it would be news to you if lower octane caused pre-ignition (which causes misfires)? Your post is not clear to me. If you are suggesting that, you should probably get to know your combustion engine better. If not, please explain.
Old Mar 17, 2020 | 06:16 PM
Misfires are always happening but to what extent are we talking about here? What I am suggesting is I have not experienced a lower octane (within reason, we are talking variations of brands of 91 for example) fuel causing a mis-fire so evident it can be audibly noticed or felt. Example: My GTI runs 32psi making over 250whp per liter. I can fill it up with 87 octane and drive to work and back with no issues. The knock sensors will retard timing and I will be fine provided I do not hammer on it. Now, if I were to hammer on it there is only so much ignition retard can do to save me if I am blowing volumes of air at 32 psi.
In regards to brands of fuel causing a mis, I have not personally experienced it. I have experienced the ECU pulling timing from one brand of fuel over another but not the car actually having a noticeable (meaning noticed without logs) misfire.
If you could explain what you are experiencing and how the brand of fuel is causing it maybe I'd understand the concern better.
Old Mar 18, 2020 | 03:12 PM
Vrodman's Avatar
So I think what is missing here is you have not experienced a true misfire from your AMG. All it takes is the slightest trigger of knock for the ECU to automatically shut down a single cylinder or multiple cylinders. When those cylinders are killed there is a huge unbalance of the engine and BELIEVE ME, you will feel it. CEL comes on and usually stays on until reset at the OBD. The cylinders will return after the engine is shutdown. But if you still have the same cause, in this case bad gas triggering knock, you will have the shutdowns repeat as soon as you jump on the throttle hard.
Again, I have studied this quite a bit. In fact I lost my first M157 motor as a result of the hard imbalance after shutdowns. Thank goodness MB replaced the motor under warranty. There are a lot of guys on this forum that have experienced the same exact things I have. Surprised they have not chimed in yet. Likely they have higher priorities with Covid and all.
That's all for now.
Cheers
Old Mar 21, 2020 | 02:25 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
You might also want to try adding like 1/3 tank of 100 octane mixed to your 93 fuel which can help reduce knock/misfire.... some folks with tune only 63's have seen misfires go away by adding a mix of some 100 octane (1/3 tank or so) to their 93 as an option you can try if you get access to 100 octane
Old Mar 21, 2020 | 03:12 PM
PeterUbers's Avatar
Vrodman and jvakos are correct and they saved my butt when I kept getting misfires on my AMS tune
i added a little 100 octane and all CEL and misfires went away and the car runs strong!!
Old Mar 21, 2020 | 04:35 PM
cdk4219's Avatar
95 SL600
Hi all,
Car -- 2014 E63S
This is textbook plug gap failure. Higher boost essentially blows out the spark at higher rpm. New plugs with tighter gaps will fix your coil problem.
Old Mar 22, 2020 | 06:33 PM
Vrodman's Avatar
coils and plugs are not the problem. For the last time, it’s gas quality/octane. Read my posts above. They are not wrong. I have original coils and plugs still from the factory. I have the Eurocharged Stage II tune. Running a 11.1 1/4 and 3.0 0-60. She is a beast. I had multiple misfires early on with the tune. I dropped Shell and went to Chevron. Have not seen a CEL or misfire in 7 months now since. Even when heat soaked. And we only get 91 here in Cali. Please explain how this can be a plug or coil issue with this factual data.
Old Mar 22, 2020 | 08:59 PM
ProfessorX's Avatar
2012 E63 Tuned, 2020 Shelby GT350, 1999 S 420
This is interesting.... I have an AMS tune and they recommend Shell to so I started using it. Every year since, I misfire bad in early spring and my mechanic tells me that it has nothing to do with the tune. I'm going to stop using Shell and see if that fixes the issue.
Old Mar 22, 2020 | 09:15 PM
Wow, that is different. To permanently shut down a cylinder over knock is extreme. I would think it would have to be excessive for this to happen. I do not have experience with the M157 but have not seen or heard of this on other platforms. Does this happen with all aftermarket tunes or does it seem to happen with only certain tunes?
Here is the funny part about Shell and Chevron. Chevron typically creates more knock than Shell at least in our area (NV, AZ, CA) which has just about the worst fuel in the country. I have better luck with Costco believe it or not. I have monitored knock with different fuels and landed on Costco at least in my area. Thankfully my GTI does not do anything excessive like kill a cylinder because of a bit of knock retard.
Is the fuel system capable enough to add a few gallons of E85 per tank? This would be a great way to improve the octane provided there is enough flow capability.
