Lag/stutter when accelerating
Old Apr 22, 2020 | 10:04 AM
Mikesoja's Avatar
2014 E63s AMG
Hey guys I've noticed that my car will have a delay with a bit of stutter/jerking after cold starts, when going to "Drive" I tried doing some research and heard the transmission might need a reflash or the multi clutch pack needs to be fixed?
However, when the car is warm it seems to go away for the most part, but it's still cold so I'm not sure if when the temperature outside goes up if itll go away completely? Is this normal or should I get it checked out?? The slight jerk/delay can be a bit unpleasant on the cold starts/first start from overnight.
oh and a side note I want to get my car tuned, would that help the issue?
Old Apr 23, 2020 | 04:50 AM
danclements's Avatar
2012 E63 AMG Estate
It's honestly just run of the mill with these cars. Mine does it and has always done it. Resetting the TCU adaptions helps, but I've just learnt to lean into it slowly when the car is cold.
Old Apr 25, 2020 | 11:58 AM
crazybear's Avatar
2014 E63
I have the same issue and also go into it slowly after cold starts like danclements suggested.
