Rough Acceleration then engine light?
What could cause this? also I dont have an obd2 scanner yet what's the best for our cars?
Also not sure if this is related but when the car is cold. It tends to jerk and lag when accelerating. e.g I start car in morning so a cold start I reverse (no issues no jerking or stutter) then I put the car into drive and then hit the gas a bit and there is no acceleration then suddenly it accels with a slight jerking motion this is all in first gear i believe. Then once the car warms up it seems to go away, well at least I havent noticed it while warm.
Could be any combination of the car being cold, maybe some bad gas, or something else. If it never happened before, I would probably attribute it to the first two. It is recommended to not apply a heavy load until the car has reached operating temps. I had a similar issue and after being more mindful of operating temp and fuel, the issue hasn’t reoccurred even after tuning.
those issues are fairly common when the car is cold, and I’m sure you can find many threads here covering other reporting the same jerkiness until the car warms up; mine is the same way.
