100 Octane on Tune Motor
Some guys who have tunes and issues with occasional misfires have found adding four or 5 gallons of 100 Octane reduces the misfires with the addition of the higher octane that helps reduce knock.
Sorry to bump this old topic but I have found this very helpful thread (and forum) with Google and I wanted to ask for expert opinions.
I am living in France and own a C43 AMG from end 2018 (390HP engine). The fuel has become very expensive, 90% of the price is Government taxes that are killing us and this is the reason why I am thinking about going for an engine tune to be able to have Flex Fuel : regular gas which is called SP98 here and Ethanol which is E85. The tune cost around 400$ and it does not increase the engine power, only allow to use Ethanol as fuel.
The fact of the matter is that is quite complicated to get the truth about E85 here because it seems like Government does not want to see many people switch to a cheaper option. Thus, I wanted to check with MB owners from other countries with eventually non biaised point of views.
Therefore my question is, is it risky for my engine to do such thing ? I am also considering doing 70% E85 and 30% regular Gas eventually, I will never try it without going through a reprog first.
Thanks in advance
Adding ~25% eth stopped the ping so it made a nice bit more power. Its not so much the retard that hurt power, but the ecu pulls boost when theres that much ping/retard.
Now that Im at 50% I can not only bump timing, I can exceed the timing in the 100 tune.
It is not a flex fuel car, and is all stock except the tuning I did. I dont use the tune I bought.
So for me the ethanol is nice, but I can also run 91 and retard the timing so it doesnt pull boost. Fyi, for what its worth
If your tune is for 91 and your timing is conservative to daily drive and you don't have any knock then 100oct is just extra protection in case your EGT's start climbing due to ambient or charge temp. You'd need to specifically run a 100 octane tune which has more timing in it. Timing is secondary to boost anyway, a bad fuel/spark tune is a lot more harmful even if youre not chasing numbers.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
