Complete engine shut down code U0028
Old Jun 3, 2020 | 01:42 AM
Matthew Byatt's Avatar
2014 E63
Hi,
Looking for info and help... Was driving for 10 min stoped at a traffic light.. was driving in comfort "C"
Traffic light turned green and car did not move. The engine was revving up and not moving. Car shut down with dash saying "do not drive" ( something like that ) or damage to gears Transmission (see dealer for services) the car would not start and would not come out of park "P" Great...so tow truck.....some dawn dish soap and water and slid it on to a flat bed.
code U028 Vehicle Communication Bus 'A' took it back to shop and disconnected both batteries. I did search the forum on code U0028 not much info. New here to the forum.. any info or help would be appreciated... Regards, Matt
Old Jun 4, 2020 | 01:31 AM
2014 E63
It was a plastic electrical clip connection on Transmission broke, disconnected and melted to the exhaust. $7.00 from the dealership.
Old Jun 4, 2020 | 06:09 AM
FastWgn's Avatar
2016 E63 Wagon
That was quite the "Phew" moment I bet!
Old May 6, 2024 | 04:24 PM
kunalrana's Avatar
mercedes c class
Merc c class
Originally Posted by Matthew Byatt
Hi,
did the car start when u had this issue and any other errors ?? As my car had the error and switched off engine and now intermittently starts but does not change gears and garages are unable to figure it out? Multiple faults errors showing all warning lights too.
Old May 6, 2024 | 05:23 PM
PeterUbers's Avatar
did you check for oil in the engine wire harness?
Old May 6, 2024 | 06:53 PM
kunalrana's Avatar
mercedes c class
Merc c class w205
the car is in the garage and they said it’s come back with over 100 faults. All visible wiring checked. Was driving and all of a sudden car error came up with our changing fears consult workshop. And then pulled up on side turned off car and then would not start up at all and does not change gears, will ask garage if checked wiring harness but I believe they have thank you..
here are some faults from rac breakdown
The errors from rac breakdown report was
System Type: ENGINE SYSTEM TEST/VALUES
Name: 651.921 - CRD3S2
DTC: U0028,Vehicle Communication Bus A
DTC: P0627,Fuel pump output; electrical fault or open circuit DTC: U0155, No communication with instrument cluster DTC: U0122,CAN: communication fault with TCS (Traction Control System)
DTC: U0111, Battery management system, communication faulty
DTC: U0212, Fault in CAN communication with steering column module
DTC: U0115,Communication with drivetrain control unit
DTC: U0128,CAN; communication fault with electromechanical parking brake controller
DTC: U0164,Communication with climate control system
DTC: U0168,CAN: No reception of EZS (electronic ignition)
System Type: GEARBOX
Name: GEAR SELECTOR - GEAR SELECTOR (INTELLIGENT
SELECTOR MODULE)
DTC: P1240,CAN bus malfunction
DTC: U0121,CAN: communication fault with ESP (Electronic Stability Program)
DTC: U0101,Communication fault with control unit automatic transmission
DTC: U0168, Control unit EZS is faulty
DTC: U113B,CAN communication with Direct select control unit, faulty
DTC: U0155, No or incorrect message from IC (Instrument
Cluster)
DTC: U0111, No communikation with battery control module
DTC: U0128,Electric Parking Brake
DTC: P179D,Emergency mode for “Direct Select” was activated
DTC: U0146, Central gateway control module; implausible signal
DTC: U0415, Invalid data received from ABS control module
DTC: P179A, Redundancy system for DIRECT SELECT
Name: GEARBOX - GEARBOX
DTC: U0141,Communication with the front signal acquisition and actuation module has a malfunction.
DTC: U0100,Engine control unit; communication faulty
DTC: U0002, Powertrain CAN bus off
Stability Program)
DTC: U0146, Fault in CAN communication with central gateway
DTC: U0001,CAN bus off
DTC: U0126, No CAN message was received from control unit steering column module
DTC: U0426,DAS (Drive Authorization System), has not sent message to enable engine start
DTC: U0028,Ignore fault code and erease fault memory
System Type: WHEEL SYSTEM
Name: TIRE PRESSURE MONITORING SYSTEM - TYRE
PRESSURE MONITORING (TPM 222)
System Type: STEERING
Name: ELECTRICAL POWER STEERING - ELECTRICAL
POWER STEERING (EPS205_TK / EPS205_ZF)
DTC: U0100,Communication with the engine control unit
DTC: U0402,CAN communication from transmisson is invalid or implausible
DTC: B210F,Terminal 30
System Type: IMMOBILISER
Name: IMMOBILISER - EIS222
DTC: U1198,Communication fault with control unit Intelligent
Servo Modul
System Type: AIRBAG ELECTRONICS (SRS)
Name: AIRBAG - AIRBAG (ORC222)
System Type: CENTRAL ELECTRONIC UNIT
Name: SIGNAL ACQUISITION AND CONTROL MODULE - FRONT - SIGNAL ACQUISITION AND CONTROL MODULE
System Type: AC SYSTEM
Name: CLIMATE CONTROL - CLIMATE CONTROL (HVAC222)
System Type: STEERING WHEEL ELECTRONICS
Name: STEERING WHEEL ELECTRONICS - STEERING
COLUMN MODULE (SCCM222)
DTC: U010087,Communication with the engine control unit
DTC: U010187,Communication fault with control unit automatic transmission
System Type: LIGHTING SYSTEM
Name: HEADLIGHTS - CURVE LIGHT, LEFT - HLIFL_222 - MT/ AT
DTC: U0168,Control unit EZS is faulty
System Type: INSTRUMENT PANEL
Name: INSTRUMENT - INSTRUMENT (IC)
DTC: U0100,CAN communication with the engine system is faulty
DTC: U0101, Gearbox control unit communication fault
DTC: U0109,No or incorrect CAN message from control unit
Fuel pump control module
System Type: DRIVER ASSISTANCE SYSTEM
Name: PARKING ASSISTANCE - PARKING
Name: PARKING ASSISTANCE - PARKING ASSISTANCE (PTS222)
System Type: ENGINE
DTC: U0028,Vehicle area network (VAN) data bus A DTC: P0627,Fuel pump (FP) control - open circuit
DTC: U0122, Data bus, vehicle dynamics control module - no communication
DTC: U0111, Data bus, battery energy control module A - no communication
DTC: U0115,Data bus, engine control module (ECM) B - no communication
System Type: BRAKES
Name: ESP AND ELECTRIC PARKING BRAKE - ESP AND ELECTRIC PARKING BRAKE (ESP205 / ESP205_AMG)
DTC: U0404, Implausible data were received from the electronic selector lever module.
DTC: P1644, Faulty variant coding
DTC: U0402, Implausible data were received from control unit
‘Transmission’.
DTC: U0100,CAN: communication engine
DTC: U0101,Lost Communication with transmission control
DTC: U0404,Implausible data were received from the electronic selector lever module.
DTC: U0402,Implausible data were received from control unit
‘Transmission’.
DTC: U0101,Lost Communication with transmission control module
DTC: U0401,Implausible data were received from control unit combustion engine.
Name: OVERHEAD CONTROL PANEL - PANORAMIC
SLIDING SUNROOF CONTROL UNIT (PANORAMIC SLIDING SUNROOF)
DTC: U0168,CAN: fault message from EIS (Electronic Ignition System)
Name: ACTIVE BRAKE ASSIST - ACTIVE BRAKE ASSIST (FCW) DTC: U0100,Communication with the engine control unit
DTC: U0401, Implausible data were received from control unit combustion engine.
DTC: U0416, Implausible data were received from control unit
“Traction system”
DTC: C10C8,Warning from the control unit COLLISION PREVENTION ASSIST
U002888
Communication with the drivetrain CAN bus has a malfunction.Bus OFF
CURRENT and STORED
Freeze Frame
Code Search
Data Stream
Old May 6, 2024 | 07:01 PM
PeterUbers's Avatar
Has the main battery outright been replaced - it should even if load testing was ok - these cars are so electrically sensitive
also a rodent could have chewed through inaccessible harness section.
water damage - any wet spots near windows... follow gravity and see if a harness got wet on interior
Old May 6, 2024 | 07:16 PM
kunalrana's Avatar
mercedes c class
main battery was changed and replaced still same issue , garages have given up with my car been sitting there for two months. And no one Leicester wants to even touch this car with this issue. And now am stuck clueless what to do,
and Merc will charge arm and a leg for this no doubt.
Old May 6, 2024 | 07:21 PM
PeterUbers's Avatar
is it worth asking if your insurance company can total it - perhaps it was in a flood 😉 or what a shame you left the sunroof open in that thunderstorm
I'm kidding of course
Old May 6, 2024 | 07:24 PM
PeterUbers's Avatar
@CaliBenzDriver what do you think - this screams harness or water damage to me ... bad ground somewhere?
Old May 7, 2024 | 03:22 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
troubleshooting
Yes Peter: high chances for water intrusion into SAM's private tub.
I read through the report from basic scanner.
​​​​​It reads like the whole CAN-C is disrupted but still chatting as ECU/TCU/ESP/ISM did submit their faults. Meaning the bus is up but worst than single-wire mode....
All faults are concentrated right there.
No DCU...
No R-SAM...
No RFK...
.... so CGW is MIA!
This fits the bill for F-SAM.
I dont think the painted GND or low-voltage are featured here. It's beyond gentle nagging.
> F-SAM Inspections :
Confirm it's missing from OBD access
Visually inspect for signs of water
Lift driver side carpet to search for water swamp
If that does not materialize EZS will be next....
