Engine jerks at speeds with low revs
Old Jul 18, 2020 | 04:28 PM
Reine's Avatar
AMG E63 2010
Hi all
I have a AMG E63 2010.
I have this very annoying thing when I drive at speeds when the engine revs between 1000 to 1500 rpm.
I can not say with certainty if it is the engine or transmission, but it jerks when I accelerates very easy/little. And only at those revs. Otherwise it's good.
There was leaklage in the intake. All gaskets are replaced there and it IS better, but still some jerks there.
It is a little worse when the engine is not completely warm.
I have read a lot about similar problems here, but not exactly what I describe.
Does anyone here have similar problems and know what it could be?
/Reine
Old Jul 19, 2020 | 05:43 AM
Mhoughland's Avatar
2105 e63s
Scan for codes
Old Jul 19, 2020 | 08:55 AM
Reine's Avatar
AMG E63 2010
Originally Posted by Mhoughland
Scan for codes
Done that. No errorcodes.
Old Jul 19, 2020 | 10:42 AM
Mhoughland's Avatar
2105 e63s
No trans codes either? I would say check transmission plug for wicking but it usually throws trans codes.
Old Jul 19, 2020 | 11:27 AM
Reine's Avatar
AMG E63 2010
No, nothing.
It feels like small missfiering.
Old Jul 19, 2020 | 11:42 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Mine does the same sometimes. It jerks and seems like tranny cant find the correct gear. Car lunges car back and forth on low RPM take-offs.
Old Jul 19, 2020 | 11:55 AM
Mhoughland's Avatar
2105 e63s
you can watch for misfires on misfire counter on a good scanner and you will see actual misfires if you have them, maybe it’s not missing enough throw codes. Also watch fuel trims to make sure it’s not adding fuel where the guys did the intake and maybe it has small intake gasket leaking air.
trans plug is dry underneath? If you see any fluid at all replace the plug and conductor plate and service tranny.
that’s all I can think of without seeing the car
Old Jul 19, 2020 | 01:18 PM
E55 KEV's Avatar
Veteran: Air Force
Thanks, swing by my house and take a look LOL!
Old Jul 19, 2020 | 01:19 PM
Mhoughland's Avatar
2105 e63s
Close to Nashville? I will.
Old Jul 19, 2020 | 01:51 PM
Reine's Avatar
AMG E63 2010
I have change oil in transmission in the correct way.
And the oil looked perfect. No difference at all.
A missfire counter whould be good.
Have any of you noticed that the tachometer moves a little up and down at low speeds? about 1mm back and forth about 2 times a second.
Old Jul 19, 2020 | 04:59 PM
E55 KEV's Avatar
Veteran: Air Force
LOL Thanks. My best buddy from the military lives there. Speak to him every day. Haven't visited Nashville yet.
Old Jul 19, 2020 | 05:11 PM
Mhoughland's Avatar
2105 e63s
I have a European shop in west Nashville. Tell him to come see me if he is looking for a Euro mechanic. Continental Motorwerks
Old Jul 21, 2020 | 03:26 PM
Reine's Avatar
AMG E63 2010
Does anyone have more ideas?
I am open to all suggestions.
Old Aug 5, 2020 | 07:51 PM
djhudson's Avatar
2010 E63
2010 E63
I have the same problem on my 2010 E63. No codes thrown or stored and up to date on all maintenance as far as plugs etc. It only happens to me usually when sitting at a red light in drive, I'll get surges/drops in RPMs. It's gotten noticeably better since I moved from Salt Lake City to southern OC, CA (denser and cooler air) but still persists slightly.
I don't have complete maintenance records and have only had the car for a few months but the Carfax shows the intake manifold gaskets were previously replaced about 15,000 miles ago. I'm wondering if the PO had the same issue.
I took it to the MB dealer after I bought it and they spent some time on it but without codes they basically gave up, and then told me it might be the torque converter, which of of course the car does not have.
The car was great on a 700 mile road trip but part of me thinks there may be a small leak in the manifold itself after doing some reading and watching Tasos Moschatos videos on YouTube. If I have to do that repair I might as well do the head bolts while I'm in there! The joys of AMG ownership.
Old Aug 5, 2020 | 08:34 PM
Mhoughland's Avatar
2105 e63s
Gets scanner and watch fuel trims to see if it’s adding fuel significantly
Old Aug 7, 2020 | 06:51 PM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
Mounts are good?
