W212 E63 Model-S top speed???
Old Jul 23, 2020 | 06:31 PM
timm206's Avatar
C63 W204 / E63S W212 / E63S W212
Hello everyone,
Before getting to the point id like to give a bit of background. I have a 2016 E63S CPO stock “i think”, I bought it a while back with 15k miles on it and per dealer the ECU/TCU/Nav were updated during that CPO certification process.
A bit more to the point now, recently i was down in Mexico and while doing a pull i was approaching the 186 mph electronic limiter or so i thought. When the car did reach 186 mph on the speedo i thought thats where it stops but it kept going and at 190 mph it was still accelerating though i had to let off due to room. So now I'm confused, only mods I've done to the car are K&N filters + Res delete.
Anyone else have been in a similar situation? Or the car is simply tuned? A glitch maybe? No signs of tampering on the ECU and when i bought the car, hand held tunes weren't available yet if I'm not mistaking “Early 2018”. Opinions are appreciated,
Old Jul 23, 2020 | 10:56 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Be very careful the tires on your car may be rated to only 186 mph. Above 186 mph the tires can suddenly explode.
Old Jul 24, 2020 | 12:03 AM
john olsen's Avatar
14 e63 s Amg8 ml63 07 screaming eagle fj 40 71 dt250 360 quads
That is some very impressive speed, how long did it take you to achieve that speed. Awesome cars
Old Jul 24, 2020 | 12:15 AM
timm206's Avatar
True, tires can easily go apart at that speed but the tires i have are rated for 186+ so they should be alright.
Old Jul 24, 2020 | 12:17 AM
timm206's Avatar
Yea these cars are awesome, love the M157 platform. Honestly not long considering its awd, it got up to 190 fairly quick and it was still pulling hard.
Old Jul 24, 2020 | 09:10 AM
cotmfk's Avatar
On the shoulder
The speedo on cars is usually off by a certain percentage. I am not sure what percent MB ones are off, but it can be as much as 5%. So, while your speedo indicated 186+ mph, you probably were going slower than the limiter-induced 189 top speed. If you can have a GPS device running, you could verify your actual speed.
Old Jul 24, 2020 | 09:46 AM
NoVAe63s's Avatar
2016 E63s
Speedometers adjust to the country you’re in, so likely it was reading K/MH.
Old Jul 24, 2020 | 10:01 AM
1MavRick's Avatar
CLS 63 and M4
so you’re saying he was approaching 120 mph when he backed off? That’s highly unlikely as these cars get to that speed in no time.
he either has a tune that wiped the governor or the speedo is optimistic.
Old Jul 24, 2020 | 11:35 AM
NoVAe63s's Avatar
2016 E63s
It was an attempt at humor, apparently not a good one. I’ll stick to my day job.
Old Jul 24, 2020 | 11:36 AM
timm206's Avatar
The speedometer is in MPH and the digital reading is also set to MPH. One would have to be a complete moron to mistake 190 mph with 190 kph.
Old Jul 24, 2020 | 11:43 AM
timm206's Avatar
i see, I'm probably just gonna dyno it and see what its putting down to make sure. I did have a uniden r7 running but couldn't really look away because there was a slight bend coming up. But ive compared the gps with speedo in other speeds and its usually .5 to 1mph off.
But even if the speedometer is off, doesnt the ecu cut power according to speed sensors?
Old Jul 24, 2020 | 02:09 PM
timm206's Avatar
Dynojet numbers
524awhp
559awtq
so not tuned for sure. Did 5 runs they were all almost the same so very consistent. Definitely not tuned.
Old Jul 24, 2020 | 02:58 PM
timm206's Avatar
Old Jul 24, 2020 | 03:08 PM
CarHopper's Avatar
E63S | X5
Jordan River Moving and Storage?
Whew -- Quite the trip from SC to Mexico. Or did you travel from the Seattle area? What kind of gas mileage did you get?
Old Jul 24, 2020 | 03:27 PM
FastWgn's Avatar
2016 E63 Wagon
No they do not....
That's one of those urban myths. A tire rated for 186 or whatever number does not simply explode at the limit +1 mph. They are designed to carry the full load of the car, for an extended period of time, on normal temperature blacktop, hitting road imperfections, at that speed. With a safety margin.
The thing that makes the tire break is temperature. Hence, if the outside temp is low, or roadway is cool (think early morning) - or even wet(!), the car is empty, etc., the tire can go pretty far above the rating with no danger.
Old Jul 24, 2020 | 03:32 PM
FastWgn's Avatar
2016 E63 Wagon
To OP - we had a similar discussion a while back. Seems like a fairly random definition of limiter at 175 or 186 for 2016 cars, no tied to sedan/wagon either.
Prior MBWorld discussion around this
Old Jul 24, 2020 | 04:50 PM
timm206's Avatar
PM’d
Old Jul 24, 2020 | 04:55 PM
timm206's Avatar
Hey FastWgn, yea i remember our discussion. Its just my thinking was that if the limiters were to vary, it would be less than 186 and wouldn't go over that but seems like thats not the case at all. I had a similar situation with my W204 C63, it was a facelift with p31 package which raises the limiter to 174 but i found the limiter to be at 180. It was also bone stock.
Old Jul 25, 2020 | 12:54 AM
brfatal's Avatar
2014 E63S AMG
He's fine. Speed ratings are done via 10 minute interval tests. That means that Z rated tires are rated for a sustained 186 mph for 10 minutes. They can relatively safely exceed that in short spirts as long as we're not talking any type of extreme speeds (I wouldn't go 240 mph on Z rated tires).
That said, the faster you're going the less accurate your speedometer is. It may have shown 190, but I doubt he'd even have hit 180 verified by GPS with that showing.
Old Jul 25, 2020 | 03:48 PM
1MavRick's Avatar
CLS 63 and M4
here’s the thing, tho...accurate or not, isn’t the speedo what the ECU is going by to determine the speed at which to cut-in? And if his speedo was actually saying 190, then there has to have been something done to the limiter, no?
*and yes...I realized my first post said it’s possible that the speedometer is optimistic. But then I thought about it, more.
Old Jul 26, 2020 | 12:55 AM
timm206's Avatar
Exactly my point, not sure how speedo being off is relevant in this case. Unless the car is using GPS data to offset the limiter? But then that doesn't make sense either since the speed limit parameter is a set value in the ECU? No?
Old Jul 26, 2020 | 02:18 AM
FastWgn's Avatar
2016 E63 Wagon
But the value displayed on the speedometer is just a value determined to be displayed by the ECU (it may technically not be the ECU but one of the other boxes).
The car knows it's true speed (as long as you have not changed wheels and tires, or at least have kept constant circumference).
The offset is set form the factory, and is set to a a couple of km/h above the true speed.
Old Jul 26, 2020 | 05:35 PM
brfatal's Avatar
2014 E63S AMG
My post was only about the tire's speed rating.
Old Jul 26, 2020 | 06:00 PM
timm206's Avatar
That could possibly be it actually, wonder what AMG techs would say. Thanks for the input.
Old Jul 27, 2020 | 01:37 PM
john olsen's Avatar
I find it interesting that the car was still pulling hard at 190 I’ve had my car to 181 I andfrom 170 to 180 it was not pulling hard still pulling still gaining but surely not pulling hard and the 181is an official time By Southern California timing and scoring, same people that does Bonneville ,I was not looking at my speedometer so I cannot verify what the car said it took me A mile and a half to achieve 181 from a dead stop. Factoid!
