Wheel fitment question?
Old Aug 19, 2020 | 01:22 AM
dufferdude's Avatar
2021 GLC63 AMG
My wagon is a 2015 e63s, which has the 10 spoke stock 19's.
The wheels I want to purchase are off of a 2018, amg cross spoked stock 20's. Hoping there's not a fitment issue, in other words needing a spacer? The 20's are on a car with CCB's mine has them too. That shouldn't be an issue?
The 20's are 20x9.5 et25 and 20x10 et55
The 19's are 19x9 et37 and 19x9.5 et52
I don't think the tires will be the issue?
the difference of the front offsets is concerning?
Does anybody have this setup? Any info would be great.
Thanks for reading
edit, found a website called willtheyfit.com
Looks like I shouldn't have a
problem with the offsets, the front tires might be problematic?
Old Aug 20, 2020 | 01:47 AM
Rehabguy's Avatar
E63S
Going with 20's you will have to dial down the profile of your tires to 30 Front and 25 Rear. I don't think you can run a 265 and ET25 up front even if you are at stock height. I might have seen a pic of someone on here running Rohanna (like candy apple red) wheels at ET25 but 245 tire up front. Also think you might need a 3mm spacer in the back.
