found the front pass is a bit warped and seems like a good time to upgrade - not srue on Brembo or Giro or RB as I did on my C63...... thoughts and best sources from those who've done it...... I know on the C63 2 piece RB's just in the front saved 14lbs of unsprung weight....
RB does a great job, FCP Euro has all of the OEM replacements you need. I ordered Brembo 2 pieces from them that look WAY better than the factory Zimmerman's and are likely lighter.
I recently replaced all 4 corners, EBC brake pads + Brembo rotors. Sourced the rotors from newparts.com. Calling them may result in additional discount:
At this time, Brembo front rotors alone are listed at $655.45, p/n 09.9764.23-Pair. There are other more expensive and top-shelf (the lightest available) 2-piece rotors from Girodisc, p/n A1-022, around $1128/pair. Hope this helps.
on my 211 E63 when i replaced the brakes i went with the 2 piece GiroDisc and EBC pads and loved them - grabbed hard - took about 5 mins to warm up, but overal was happy and like the look of them too. Don't think you can go wrong with either Giro or Brembo - i am not a fan of RB - read to many bad experiences from others with failure.
i bought mine direct from girodisc
I'm having RB installed on the Fronts and Rears
Once they're done I'll post up how they are
It may be about a week since I'm getting the calipers powder coated at the same time
