Oil Change
Old Jan 16, 2021 | 05:11 PM
Sugar_Mouth's Avatar
2014 E63S, 2018 GLC 300
Oil Change
Had 15 qts laying around, used 9 yesterday. I'll let you know when it blows up. :-)
Old Jan 16, 2021 | 06:31 PM
kenneyd's Avatar
poop
you suck it out the top or drain it from the bottom?
Old Jan 16, 2021 | 06:41 PM
Drain. I extract the GLC300. My extractor does not work on the E63.
Old Jan 17, 2021 | 06:04 AM
SAMzE63s's Avatar
E63s
5w30? isn’t that too thin?
Old Jan 17, 2021 | 06:51 AM
Gazwould's Avatar
S204 C250 CDI Sport
So is Dexos 2 the only manufacturer oil spec ?
Old Jan 17, 2021 | 09:45 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Hmmm?
Old Jan 17, 2021 | 11:00 AM
For the record, I do not recommend this. I planned on a bunch of highway miles with light load and had a bunch laying around. Any type of load and you will want 40wt.
Old Jan 17, 2021 | 04:11 PM
E55 KEV's Avatar
Veteran: Air Force
Perhaps only drive about 3k miles or so.
Old Jan 17, 2021 | 04:24 PM
Gazwould's Avatar
S204 C250 CDI Sport
Thank God for that , only Dexos 1 too , it's an engine flush at best .
Not the 5W30 I would use..
The 5W30 Daddy..
See the marketing rubbish they put on the packaging .
Guys viscosity doesn't determine protection it's film strength measured in psi all determined by the oil basestock groups and additive package !
Old Jan 17, 2021 | 07:30 PM
Agree!
Old Mar 18, 2021 | 11:46 AM
wseikow's Avatar
E63S 2016 [W212 ] :::: E55 2002 [W210 ] [31k miles] ::: TARGA4S 2007 [ 997.1 ]
Which oil do I use for oil change ? 5w-40 ?
2016 E63
Old Mar 18, 2021 | 12:16 PM
E55 KEV's Avatar
Veteran: Air Force
2016 E63
Sure. That's what my dealer uses. I prefer Mobil-1:
Mobil1 FS X2 European Car Formula 5W-40 Full Synthetic Motor Oil, 1 Quart 44618: Advance Auto Parts
I keep a quart in the trunk. When I get the low oil alert I've been topping off with Castrol from Walmart:
Castrol Edge 5W-40 A3/ B4 Advanced Full Synthetic Motor Oil, 1 Quart - Walmart.com - Walmart.com
Old Mar 18, 2021 | 01:38 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
2016 E63
Here are the specs for the various MB engines, and a spec for all the approved oils under 229.5
Regards,
Joe
File Type: pdf
Old Mar 18, 2021 | 01:45 PM
TEAsE550's Avatar
Veteran: Air Force
13 E550 Coupe & 99 C280
Enlighten me???? Why wouldn't ya'll use Kirkland Brand, other than it's the wrong weight?
Old Mar 18, 2021 | 02:05 PM
E55 KEV's Avatar
Veteran: Air Force
Some here are using Kirkland. Aren't the key words here "wrong weight"? Other reasons besides wrong weight:
No Costco Membership
No Costco Near
Old Mar 18, 2021 | 02:17 PM
TEAsE550's Avatar
Veteran: Air Force
Originally Posted by E55 KEV
Someone is using Kirkland - You are LOL. Aren't the key words here "wrong weight"? Other reasons besides wrong weight:
No Costco Near
Yes I am and have been using it in my wifes 1999 C280 since Costco sorted Warren to blend their synthetics (about 120K miles). I wouldn't use it in my E550 since it is the wrong weight, but if they made a 0w - 40w I would in a heartbeat!
Old Mar 18, 2021 | 03:23 PM
AngryScotsman's Avatar
E63S
Since I haven't seen anyone post up a UOA, I doubt anyone will have a valid reason to use it or not use it.
I'll be doing an oil change this weekend using Rotella T6 and sending in a sample in of the OEM stuff for a UOA.
Then, in a year's time, I'll do another with the T6 to have a comparison with. Be interesting to see the difference for my engine.
