ARRGHH stripped coil torx bolt, with a twist
Of course it was the very last bolt that stripped on me
The hardest-to-reach ignition coil torx bolt on the rear passenger side cylinder (#4 cylinder?) stripped out. I made the mistake of trying to brake it loose with a 1/4" 12-pt socket on a 1/4 drive before switching to a 6-pt socket, but by then it was too late anyway. A proper E8 socket doesn't fit on it now.
Just tried my rotary/Dremel tool with a 1 1/4 cutoff wheel to slice the bolt head off, but not enough space to cut without tearing into the heat shielding.
Short of sacrificing the coil pack itself by destroying it so I can get to the bolt, do I have any other options?
Thanks all
Thanks all
Received 2,124 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Just get a new coilpack...cut off the bolt head
or Dremel a straight line like a flat head .. then use screwdriver
I’m going to have to cut off the head. There’s no room to get dremel a notch into the head given it’s the bolt closest to the firewall underneath the coil pack.
The following 2 users liked this post by Mojo20032004:
amgggg... (04-28-2021),
thesaintusa (10-11-2021)
https://www.ebay.com/itm/FLEXIBLE-SH...-/373118950592
I bought of these. Great for tighter spaces that dont require as much torque to tighten/loosen
Thanks all
Thanks all
