Spark plug replacement?
Replacement from the dealer is kinda pricey and I am completely ignorant when it comes to car maintenance.
I don't drive the car very much.
if you do take your car to an independent shop to install new plugs BE SURE they understand how to index the new plugs properly!!!! if they go with MB OEM plugs they should index properly if they are installed and torqued to the correct spec. but if they use a different plug then you to ensure the ground strap properly lines up with the injector (SEE THIS: https://mbworld.org/forums/w212-amg/...ark-plugs.html)
Thanks!
