Stock data log numbers
Hey all. I just picked up an M157 and would like to check it's data logs vs some other logs from guys with stock motors if available. Just wanted to check health of the car before starting the mods. Thanks in advance
So here is a log using my Ndash OBD logger - I have exported it in Excel format so you don't need the Zeitronix software to read it. *Disclaimer* Although this is from a M157 engine, this was in my STOCK W216 CL63 AMG so might be slightly different stock tune to the W212, but I think negligible. I'm interested in comparing with others out there, whether stock or tuned.
I assume the software is doing some kind of interpolating between values, since the time steps seem too short compared to what I've seen from OBD2 output (Torque app & HPTuners). Is there a way to turn interpolation off and output only direct data?
What are the units for speed (kmph?), IAT (Celsius?), Boost (psi?), and FRP?
You can sort of tell by comparing different values, but can you add throttle position to the Excel file?
EDIT: To give you an idea of how it will look, here is a screenshot of the software with the data. Obviously one just slides the cursor along to where you want and the data numbers are actual for that point. I guess similar to HPtuners.
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1890x985/zeitronix_3ddb9d912473e185d0b7d7331e864e9157091aae.jpg)
