Adjusting Parking Brake
Old Jun 25, 2021 | 09:32 AM
crazybear's Avatar
2014 E63
Hello all,
I recently changed the rear brake pads on my 2014 E63 and wanted to adjust the parking brake, but couldn't figure it out. Does anyone have experience/ advice on how to do it properly?
Old Jun 25, 2021 | 11:00 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by crazybear
Hello all,
Procedure attached.
File Type: pdf
Old Jun 25, 2021 | 11:04 AM
crazybear's Avatar
2014 E63
I tried to follow this procedure, but had a hard time finding the adjustment wheel. Does the rotor need to be removed to access it?
Old Jun 25, 2021 | 01:21 PM
Valvestud's Avatar
Perhaps the answer is here. I'll be putting mine up on my lift to finish other maintenance and I'll take a look.
Old Jun 25, 2021 | 02:10 PM
crazybear's Avatar
2014 E63
Yea seems like its behind the rotors. I dont recall seeing that grommet with the access hole to the adjustment wheel. Our model might be different where the entire rotor needs to come off. Just guessing.
Old Jun 29, 2021 | 04:49 PM
crazybear's Avatar
2014 E63
does anyone know if the rear rotors need to come off to adjust the parking brake?
Old Jun 29, 2021 | 06:15 PM
Valvestud's Avatar
I just looked at all docs related to anything on the rear wheels. Even the procedure for removing the parking brake indicates you need to take of the disk. Another doc indicates you need to remove the caliper to remove the disk.. duh. I have a feeling the adjuster may be behind/underneath the caliper.
Regards,
Joe
