M157 Exhaust upgrades ?
Was looking to get some more insight on the different kind of exhaust upgrades for the 15’ e63s. I just bought one & was thinking about making the exhaust a little more loud, but don’t want anything crazy. I was thinking about doing resonator delete & replacing them with straight pipes but not sure if that will make it sound any better. I was also thinking about catless down pipes but I think that’ll be a bit much. I’m leaning towards resonator delete but wanted to see if anyone had any good recommendations. Thanks….
The following 2 users liked this post by sickSVT:
Chest Rockwell (11-04-2021),
S63AMG888 (11-03-2021)
For sound, most people simply cut out OE resonator and replace with X, H or Straight pipes. You will hear a plethora of different explanations as to what's best (good luck w/ that).
For "power", many have gone the downpipe route. Some worry about the smell. Some worry about SMOG.
I was literally just looking at the whole post downpipes section from supersprint (it eliminates the resonator) w/ the F1 mufflers... but ultimately think it's not worth the money.
I wouldn't worry about it being too loud, Although downpipes make the car considerably louder there isn't any droning at all. If smell is a consideration then that would be a bigger concern as you can smell how much fuel you are using when stood behind the car... There's not any smell in the cabin at all. As for smog you do get a little bit of smoke on a cold morning but I find that, that goes away once the engine is warm. I didn't really want to cut the standard exhaust which is why I ended up going downpipes (that and i wanted to see what stage 2 was like) you could always look at getting some sports catalysts instead of decat downpipes as this would increase the sound but you wouldn't get the smell.
KingofCorsa (11-03-2021)
Really like those rear silencers (mufflers as you say that side of the puddle!)....if for nothing more than the look. What brand are they (do you have a build thread)? Are they anti-socially loud!! I assume your car is M157 powered.....are they available for the M156?
E63_SauceGod (11-22-2021)
ALFAitalia (11-04-2021)
Thank you for your detailed reply....I think just adding the tips to the stock silencers (somehow!) will do the job for me....it will get that look at least. Personally I think they are quite loud enough from the factory!!
W205 '15 | '17 C43 | '18 C63(current) | '15'GL350 | '16 G550 (current)
