Advice on preventative maintenance
Old Jan 12, 2022 | 11:13 PM
sushiboiiii's Avatar
E63
So the motor is going to be coming out of the car due to the fact that the turbo seal is leaking. So is there anything that you guys would recommend me doing while the motor is out? Thanks in advance.
Old Jan 13, 2022 | 08:12 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
I would look at anything rubber, hard to reach coolant lines, fuel lines, etc. What were your symptoms in identifying the turbo leak? Just an oil drip?
Old Jan 13, 2022 | 03:44 PM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
With the engine out, there's a hell of alot you can do. The real question is how crazy do you want to go?
If I were pulling the motor out, I'd reseal the oil pans, replace the waterpump, turbo coolant lines, replace the oil feed orings (or lines), thermostat, chain tensioners, cam sensors, reseal the valve covers, replace the cps, rear main seal, inspect the timing chain guides and possibly replace, inspect and possibly reseal the front cover, and exhaust manifold gaskets. Also an awesome time to upgrade your turbo inlet pipes for a bov and/or meth.
Old Jan 19, 2022 | 08:07 PM
E63
Originally Posted by WANTED!!
With the engine out, there's a hell of a lot you can do. The real question is how crazy do you want to go?
I will for sure double check those area since the first time the motor was out we replaced some of the more noticeable parts that needed to be replaced. thanks for the input!
Yeah the first time the motor was out we replaced some of the lines, but not all since some of them were in better shape, but who know that was a year ago so they may have gone bad now. Thanks for the advice. As far as symptoms there an unknown leak right by the turbo where it almost looks like a little pan ill snap a pic when the engines out and lots of smoke during warm up or when the engine is still cold and I come to a complete stop, goes away when its warmed up. Also WOT smoking like a locomotive.
Old Jan 21, 2022 | 12:01 AM
BiturboSF's Avatar
E63 M157
Wow what year & how many miles are on your E63?
Old Jan 21, 2022 | 07:11 AM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
I would be going with aftermarket turbos too but I understand not wanting to mod it.
Old Jan 24, 2022 | 08:12 PM
E63
2012 and a little under 85k
Yeah thats the reason the engine was out the first time to install W.3 turbos.
Old Jan 27, 2022 | 01:42 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
coils and plugs plus trans front seal
put a scope down each hole.
Old Jan 29, 2022 | 01:47 AM
jonii's Avatar
Alpha 9 E63s AMG Biturbo
oil thermostat cap gasket, coolant feedline plastic housing on the back of the left cylinder head, also id check yur alternator brushes.
