Remote back of the seat?
Old Jan 19, 2022 | 11:24 AM
mincon5's Avatar
2010 W212 E63
Hey!
The inflatable side bolster on the passengers right side stopped working, so I’m suspecting a broken air bladder.
canr figure out how to remove the back of the seat though. Can’t find any screws and tried applying force both up and down. Are there any tricks to removing it without breaking anything?
Last edited by mincon5; Jan 19, 2022 at 11:30 AM. Reason: Accidentally removed text
Old Jan 19, 2022 | 11:53 AM
ALFAitalia's Avatar
Alfa 159
This is what they look like from behind to give you an idea of how they fit....pull out the bottom then drop them down....
Old Jan 19, 2022 | 01:35 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
On my CL you had to move the lower flap by disconnecting a couple of elastic straps from the front of the seat. That allowed access to a couple of screws at the bottom of the panel. After that it just slid up. I had a air line fitting cracked. I just used a gasket maker compound to seal it up. Has worked since. Good luck.
