360mm direct fit carbon rotors
Look at this weight! 15,2kg / 33,5 lbs. So front giros weight is 16,6 lbs if I did understand correct.. So the save is 7,6kg / 16,9 lbs!!???
i changed mine from 36cm to 39cm last month, i bought the one of w231 sl63 w205 c63s w213 gts...(not carbon one) they fit perfect, you just have to install spacers 1.5cm (39-36cm=3, 3/2=1.5cm) and longer bolts and that's it no need brackets.
edit: i was wrong 550 have also 360mm i just checked today.
Front disc: 3500USD/Pair 5kg 11lbs each (includes hat)
Front pad: 288USD/Pair
Rear Disc: 3600USD/Pair 4.5kg 9.9lbs each
Rear pad: 268USD/Pair
https://www.cmcmat.com/
You can ask for Daniel.
So it’s decision time. Used inspected larger OEM CCB rotors and gold calipers vs keep my red calipers and do new 360mm CCM rotors and pads for the same cost.
or, give up 30lbs and just run the Girodisc. I read people either love ceramics or hate the soft cold pedal. I’ve never driven a car with ceramics.
hmm.
Still looking for rear weight with the parking brake drum thing. Still searching.
https://tro-nik.com/different-rotors...o-side-review/
On a daily driver, I will not put the CCB's and if I did, I would have to take pictures of the rotors and the calipers every time I have some one taking the wheels off.
I'm going to just run the already purchased Girodisc at this time, which saved me 24.6 lbs total all four corners. Chasing the extra 40lbs weight saving going from Girodisc to CCB makes no sense to me financially. I wish I could afford it, but I just can't. I tried kicking and screaming to find a cheaper way, holding out to the last minute from using iron rotors, and kind of not really did with the carbon 360mm above. It's still too much for me and I have not the funds to spend $300/lb weight savings on brakes.
Ratz, I tried.
Thanks everyone for coming along for the ride!!
LOL.
