360mm direct fit carbon rotors
Someone recently found stock steel rotor sized CCB rotors. They swap right in. For the life of me I can't find that dang thread.
I keep searching and regretting not bookmarking it. I think it was from late 2021, probably in another area here at mbworld.
Anyone else seen it?!
Some guy supplies or has a source for CCB rotors with same dimensions as our stock ones - diameter, offset, etc. etc. to swap right in using the red stock calipers.
I swear I read it on mbworld on my phone a few days ago, and, can't find it now.
I already have Giro Disc's coming, but, for "next time" would love to plan for CCB if I can just find the post and it's not a $20k purchase
BCP (02-09-2022)
BCP (02-10-2022)
https://mbworld.org/forums/sedan/827...ccb-discs.html
Most ccb rotors overseas custom spec'd to oem 402mm & 358mm can be made for 1000-1500 a pair depending on supplier. We should do a group buy 🧐
I’d buy those rotors ^^ if we get the dimensions right I’m in!!
And, I think I might have found the thread! However I really thought the thread I remember had 360mm rotor drawing pics with dimensions etc etc.
I guess I’m just crazy. I PM’d the OP in that thread about W212 rotors.
Who’s in for group buy?!
Well **** @jonii beat me to it and I never noticed! I wasted so much time searching google, if I would have just read his post above … lol.
Thank you @jonii I think that was it.
I’d try CCB for those prices, wonder what they weigh in the slightly smaller “iron” 360mm size?
RVAE34 (02-26-2022)
Or I could just keep looking for a good deal on stock parts I guess...
https://www.ebay.com/itm/25538989319...0AAOSwd85iDUk9
I.T. Guy (03-01-2022)
Update - I got a PM back asking if we have rear electric parking brake. I don't think so, anyone confirm? I asked him to confirm if they are stock iron size replacement carbon rotors or if they are the larger OEM CCB rotor sizes... awaiting a reply and if they are even available.
I also found a guy in NJ that wants to swap CCB's for Irons from a 2013, another in California that is outright selling a set, and there's a set on Ebay now with Calipers for $8900.
Used makes me feel weird since I don't know if there's anything wrong with them.
I also got a quote from my local dealer for CCB calipers, rotors, pads it was $32,000 after taxes LOL LOL LOL they said I could get 10-15% off that.
Umm no.
My Girodisc's FINALLY arrived. So looks like all my options are presenting themselves all at the same time.
Keep you all posted.
Umm no.
I read fronts are 13.9 lbs but can't find info on the rears. I haven't had a ton of time to search either, maybe this weekend I can google-fu
Edit: looks like the rears are 9ish
Those Giros save really much weight. Here is new Brembo CLS550 front disc. Its 360mm like on M157 AMGs, but maybe a different somehow?
Look at this weight! 15,2kg / 33,5 lbs. So front giros weight is 16,6 lbs if I did understand correct.. So the save is 7,6kg / 16,9 lbs!!???
nemiro (03-16-2022)
(Rear is 16.6 lbs)
PekkaH (03-16-2022)
So, another way to go at this is to get the bigger CCB and use adapter brackets. Racing brake says this kit will bolt up with adapters
https://racingbrake.com/mb-crk-07/
Still a bit pricy.
I did find a 2013 with CCB that wants to swap, but it's RWD and I'm not sure they will fit my 2016 dust shields and AWD etc.
The quest for poor-man's CCB swap continues.
Still a bit pricy.
Does anyone know how much original rear disc weighs is? Would be interesting to compare that weight difference to Giros also.
I.T. Guy (03-17-2022)
In the Marketplace here there are some in Monterey but the nearest friend I have that way that would know what to look for is in Newport
I found the "source" for making these, not sure if they will deal with end users. I just reached out to a contact there I got from a bimmer board.
If they do sell direct I'll find out min. run numbers and report back.
