Cup holder w212 rear center console armrest
Old 02-13-2022, 05:23 PM
I.T. Guy's Avatar
Received 1,148 Likes on 601 Posts
2023 E63S Wagon
Cup holder is broken. Kids rock!
Dealer only sells whole armrest assembly for over $1,000.
Besides used junkyard or eBay ones, how to fix?
Old 02-13-2022, 10:08 PM
Z34TTS's Avatar
E63s
Man that stinks.. I would say that car-part.com may be good or ebay.
Old 02-13-2022, 11:56 PM
PeterUbers's Avatar
Received 2,037 Likes on 1,420 Posts
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
How is it "broken"?
Old 02-14-2022, 12:34 PM
I.T. Guy's Avatar
2023 E63S Wagon
How is it "broken"?
It wasn't operating properly. I tried to fix it, it was cold, I was impatient and snapped some little piece off that's an eyelet for one of the plastic arms that makes the magic unfold
Old 02-14-2022, 02:44 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
No more drinking in the car. Problem solved 😂
Old 02-15-2022, 08:52 AM
Mojo20032004's Avatar
2014 E63S
noted*no kids, got it!
Old 02-17-2022, 10:15 PM
I.T. Guy's Avatar
2023 E63S Wagon
Still haven’t found one cheaper than the CAD$1380.00 the dealer wants.
Argh.
Old 02-20-2022, 11:18 AM
Johnny Rad's Avatar
W212 E550 4M P2
😔 Sorry to see this.
Between plastic bits that can’t withstand bored little hands and replacement parts that only come in much larger, expensive sub-assemblies… argh.
Wishing you good luck on a reasonable DIY solution for both…
Old 02-22-2022, 02:22 AM
speedydriver's Avatar
E63 AMG S
Might I add that I’m not 100% sure color match on leather will be spot on. I had plastic engine cover replaced and purchased from factory and their paint colors don’t match either. So I’d prob confirm with them if you do go ahead and replace the entire armrest assembly
Yakatak (02-22-2022)
Old 03-08-2022, 10:41 AM
Tork?'s Avatar
W212 E63
Does the plastic tray insert separate from the arm rest?
Old 03-08-2022, 02:16 PM
PeterUbers's Avatar
Get this and retrofit pieces
https://www.ebay.com/itm/2010-MERCED...-127632-2357-0
search "w212 rear arm rest"
The following 3 users liked this post by PeterUbers:
Blade Canyon (03-10-2022), I.T. Guy (03-08-2022), jvakos (04-03-2022)
Old 03-08-2022, 02:23 PM
I.T. Guy's Avatar
2023 E63S Wagon
BOUGHT!
THANK YOU!
I've been cruising eBay every time I remembered to and even went to some local scrap yards.
THANK YOU! THANK YOU!
PeterUbers (03-08-2022)
Old 03-08-2022, 02:25 PM
I.T. Guy's Avatar
2023 E63S Wagon
We will soon find out
Old 03-08-2022, 02:56 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Or you could take the grumpy old man's way out and just glue it shut!
Old 03-08-2022, 03:52 PM
PeterUbers's Avatar
seems like the whole plastic construct is glued to the leather bound piece... itll
be easier to pry apart with the armrest out of the car and also you can start with the soft liner in the tray, that pushes down and out to expose foam and easier access to separate the laminated leather piece and plastic construct
alternatively you may be able to lure the functional cup holder pieces away from the eBay track and then install onto your existing track and that'll be the easier task with best outcome
they also sell this
for as low as $200
shipped ... this one is listed as "black interior" - you could simply remove this arm rest and replace with yours
Old 03-30-2022, 03:28 PM
I.T. Guy's Avatar
2023 E63S Wagon
Update
Couldn't figure out any way to transfer the cupholder (or any) of the armrest over without butchering everything. So now I'm on the lookout for a black armrest, or that whole rear seat LOL.
Yakatak (04-01-2022)
Old 03-13-2024, 03:36 PM
jeiholzer's Avatar
2014 C250 Base class
I'T Guy did you ever figure out how to replace just the armrest? Do you have to remove the whole seat to do it?
Old 03-13-2024, 05:22 PM
I.T. Guy's Avatar
2023 E63S Wagon
Sorry I never figured it out.
I stopped when the used one I bought was beige, and the guts 100% could not be transfered.
It looked to me like where they cut it off the car to ship to me, I could not do the same on my car - seems to me the best bet is to get the whole seat back that includes it like the one PeterUbers posted in post 15
Someone else may know better
Old 03-14-2024, 01:35 AM
Yakatak's Avatar
2016 E63 S AMG Wagon
Smile
Maybe, back up and try to repair the broken part. I've repaired lots of plastic car and motorcycle bits. Do you have a pic of the damaged part? Ether of you.
Old 03-14-2024, 09:23 AM
I.T. Guy's Avatar
2023 E63S Wagon
I replaced it
With a 2023 cupholder.
Old 03-14-2024, 10:21 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
What color do you need? I have a donor car. Oh, what car?
Never mind, you got it....I went to US Public schools and can not read.
Old 03-14-2024, 11:57 AM
jeiholzer's Avatar
I thought about replacing the part that I need but I cannot buy the part only. So I bought the while armrest. I thought about removing the piece from the new one and putting it in the old one but I am unsure. It has to go into a groove that I can't seem to pull the new on out of and it requires a pin that I am unsure if it will seat well. I am just not sure. It seems like it should just come out of the groove. See the image. I pointed an arrow to the part that is broken. The cup holder, to the right, flips back over to the left. I circled the a slot the arm moves in and circled the pin, opposite side, that I would need. It seems like it would be fairly simple to pop the pin and wrangle the arm out. But I can concerned with breaking something and having to buy a whole new rest again.
I am also an idiot as I was thinking the seat was one continuous piece. In my case the left seat folds down and I think I can remove one part and be able to replace the arm rest. We'll see. I may still have to remove the left seat to do it.
Old 05-23-2024, 06:14 PM
NavyHusker's Avatar
2014 E350 4matic
I have the same problem and purchased a replacement armrest from eBay for my 2014 E350 4matic sedan. Problem is that I cannot figure out or find instructions on how to remove the existing one to replace the used one I bought.
Thanks in advance to anyone who can assist.
Old 05-31-2024, 03:29 PM
jeiholzer's Avatar
I finally figured it out and created a terrible video that I hope can help you and others.
I.T. Guy (06-04-2024)
Old 05-31-2024, 06:02 PM
PeterUbers's Avatar
I finally figured it out and created a terrible video that I hope can help you and others. https://www.youtube.com/watch?v=MydgYuM8Xbo
great video and contribution, thank you!
Quick Reply: Cup holder w212 rear center console armrest
