E63 Brake Rotor Kits from eBay
Hello!
New member here based in New Zealand. I've got myself a 2013 E63 AMG (M157, 212-074) which is in need of all front and rear rotors + pads shortly.
I've been quoted some outrageous amounts so I looked online and found some full kits available on eBay. Prices seem considerably better but thought I'd do a sanity-check with the hivemind here before ordering.
Has anyone used these kits? Any opinions etc or alternatives would be awesome. Link below:
Brembo Kit
Cheers mates!
Brembo Kit
Cheers mates!
Received 2,039 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Seems like a good deal - curious others' opinions as well
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1170x1932/2f0d83a0_f0e3_4096_9611_cae385e70e5f_b16e4c1fdd1b207443531b57b72dc890f266aa22.jpeg)
Jonny English (03-02-2022)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/920x2000/b0544ef4_df22_45e8_9371_0dddbbc99502_85711b7bd293501f782ce9ef016954e2167e10c7.png)
He takes 5% off if you buy from Him - $1519
i did the legwork for y'all - it seems legit
The following 2 users liked this post by PeterUbers:
Jonny English (03-03-2022),
mbwillgrubs (03-03-2022)
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
The drilling, or in MB case, dimpling is to give hot gasses generated by the pads somewhere to go. Brake fade is the accumulation of a gaseous layer between the pad and rotor eliminating the friction effect. Cooling is helped by the center fins which throw air outwards from the inner layer of the disc and cooling air being drawn through the disc hub.
Do appreciate the leg work, this is in all our futures.
PeterUbers (03-03-2022)
Brembo Front Rear Brake Kit Rotors Low-Met Pads For MB W212 S212 C218 B06 or U70 | eBay
I bought these and have been happy with them - they are all brembo parts
Ebay motors has done pretty well by me over the years - sure you get some **** parts but Ebay does make it right.
Yeah, i would obviously reach out to the seller honestly and see. You will want to verify compatibility with them in writing somewhere so if they dont fit/work you can get an easy return though ebay.
Zimmers aint bad. If they're 2 piece even better. I pulled an old set of 1 pieces off to put these 2pc ones on.
Just had these installed
https://www.ebay.com/itm/For-MB-W204...-127632-2357-0
they were installed by a former Benz master tech and they work perfect for fronts. I got the rear rotors and pads from fcp
install was $352.
whole job cost ~$1400 for all four rotors, pads, 2 sensors, install.
Braking is smooth and strong and quiet
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/920x2000/ee834dda_fe34_4835_afbc_1f8dfd96b97e_139d7bf48846467277f177645eeeb4474cfdec4b.png)
install was $352.
E63 SL55 996TT C5Z06
install was $352.
install was $352.
this is ENTIRELY thanks to YOU John for finding me the path forward and keeping prices reasonable - THANK YOU!!
