I took my 2012 CLS63 non-PP (RWD) to the local 1/8 mile track today. For reference, my car has the following mods:
-Stage 2 eurocharged tune
-Decatted oem downpipes
-Custom tcu tune from VTECH
Tires were 285-35-19 MT ET Street SS on PP 19" wheels. This set-up is heavy but it hooked.
My best time was a 7.53 at 95.21 mph with a 1.88 60 foot. It was about 91 degrees Fahrenheit with 45% humidity. I think there is room for improvement on the 60 foot time. Does this seem to be in line with other m157 powered cars with an ecu tune?
I was expecting more out of the hole with the tcu tune.
I wasn't able to brake boost like I was hoping due to the car bogging when I tried this. The best time was achieved by smashing the accelerator from idle.
I was nervous to use race start/ launch control due to the increased torque limits from the TCU tune but I'll try this next time and hope nothing breaks!
Any input is appreciated!Thanks!
Reason: Adding info
Those are pretty close to stock times, aside from the weather. DragTimes says it was 3500 DA, so that does hurt a bit. The calc they have adjusts your 7.53@95.2 to 7.40@96.8. That's a little faster than a stock car, but not by much. I'm not familiar with the VTECH TCU tune.
I did expect a little more out of it. The tune was on the car from a PO so it's possible it's not 'stage 2'. Vtech has been around but mostly on the m113k platform. He recently started doing tcu tunes on this platform.
@Lriver1004 There are plenty faster M157 cars on this forum, but thanks I hope you solve your cars problems and get it going faster like it should go!
@cotmfk Thanks man. Look my 60ft, its just 1,78. I need to get it on about 1.70 levels then I would be satisfied and get better times on 1/8 and 1/4 mile. I think my tuner needs to fine tune TCU and I need to learn to launch better also.
After doing some reading it seems that my car is more in line with a 'stage 1' eurocharged tune equipped car. I need to get this thing on a dyno and see where my hp/tq numbers are to confirm
I'll have to check them out! Your car is moving. Are you on 91/93 or ethanol?
Thanks, im running only straight pump gas, no ethanol blends. And no meth injection. If I do those or even one of those my times would be a lot better.
