Catastrophic Failure due to oil sensors leak
#226
Received 2,070 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
chassis (02-16-2023)
#227
#230
2016 E63 S AMG Wagon
I ordered a set of 4 Cam position sensor extensions from ZZ. (Yes there is a cam position sensor only set available: 2011-20 Mercedes Benz 4.7L Camshaft Position Sensor 3 Pin Harness Extension M278). The connector for the sensor end is identical to the original. The harness end connector has additional bits to connect to its original intended application, but fits perfectly, including weather seal. Wagon starts and runs fine...no codes thrown. Yay!
#231
#233
Received 3,950 Likes
2017 GLE350 4MATIC
So, no. Silicone in the connector is not a solution. New sensors and magnets are the solution to the root cause, which is failed magnets and sensors. Replacement harness and ECU are sometimes required if the saturation is sigificant enough.
NH_E63 (03-06-2023)
#236
Oil wicks along the metal male-female contacts, which are in intimate physical contact. It then wicks along the harness-side contact along the wire and into the insulation, and from there it goes anywhere it can go.
chassis (03-06-2023)
#237
Update: After installing these sacrificial harness extensions on my cps I am happy to report the oil is no longer appearing on ecu pins.
It’s been a few months since install. I have some for the magnets too but didn’t get around to installing them yet
