Lowering E63s Wagon
Old Aug 5, 2022 | 10:41 AM
  #51
I.T. Guy's Avatar
2023 E63S Wagon
Thanks Ken
But shouldn't it still drive straight? Or are you suggesting every lowered car pulls to the right and no one cares? If so that's information I could have used before the mod.
I understand camber changes, which we can't adjust, which affects toe, which we can adjust and get close, but, shouldn't it still be made to not pull right even if not in perfect spec?
My fear is burning up these tires in a week
Old Aug 5, 2022 | 10:48 AM
  #52
kenneyd's Avatar
poop
Originally Posted by I.T. Guy
Thanks Ken
I understand camber changes, which we can't adjust, which affects toe, which we can adjust and get close, but, shouldn't it still be made to not pull right even if not in spec?
Yes, even with neg3 degrees, if it's even side to side, it was track straight.
I'm suggesting the possiblity that one side is done one way, and the other side was done differently casing a ~1.5 degree difference from side to side, which would cause a pull.
When you tighten both of those strut bolts, was the suspension supported or was it fully drooping?
Old Aug 5, 2022 | 11:45 AM
  #53
I.T. Guy's Avatar
2023 E63S Wagon
Thank you!
Drooping.
Whoops, I'm guessing I did that wrong?
Old Aug 5, 2022 | 12:05 PM
  #54
kenneyd's Avatar
poop
Thank you!
Drooping.
If you did both of them when they were fully drooping, then you did it right for less negative camber
Old Aug 5, 2022 | 12:29 PM
  #55
I.T. Guy's Avatar
2023 E63S Wagon
OH!
Well maybe I need to do those bolts again absolutely fully drooped. I had a stand taking SOME of the weight off the droop, but just like 10-20 lbs or so, because I didn't know how far the axel would pull out and cause different problems if I let it hang too far. Maybe that made it uneven?
The alignment place when I asked "what next" said "try swapping tires left to right". Umm.
I have a weird feeling they didn't even touch the car, although I checked out a few references and they have a great reputation. I don't mind paying I just want it fixed and not chased for weeks. It has to be easily solvable by someone competent! It was 100% fine before I dinked with only 6 bolts. I admit and know I did it, just fixt it please I even told them I was there because I just did the springs myself so it's not like some mystery alignment job.
I'll keep you all posted.
Old Aug 5, 2022 | 12:45 PM
  #56
I.T. Guy's Avatar
2023 E63S Wagon
P.S. anytime a change in links/front coil heights I need another alignment? So if I raise it to stock every winter lower every summer?
Old Aug 5, 2022 | 02:43 PM
  #57
kenneyd's Avatar
poop
In theory, yes.
in real life... no. (other than toe)
any time you change the front end geometry, if effects the alignment specs, true. most of it is camber and toe. But as long as your are lowering both sides exactly the same, then the camber gets changed exactly the same. There is a wide range of factor specs, maybe +/- a 0.55 degree or whatever, likely you will still be within spec.
Having said that the toe absolutely needs to be set with ever height change. but you CAN do this at home with a two tape measures in just a few minutes.
Old Aug 5, 2022 | 03:56 PM
  #58
I.T. Guy's Avatar
2023 E63S Wagon
Makes sense.
Maybe I wasn't as precise on height as I thought I was? I used calipers to measure the purple adjustment ring to perch to be the same on each side, yielding a a ground to fender measurement that's 2mm different. I just figured no big deal. Maybe it is.
I'm going to drive it a few more days see if I can get it to settle, and then set the real height I want the kit to live at and deal with the alignment then.
Also, At 1:00am doing the lowering job I noticed the left strut upper bearing is crunchy and very stiff, hard to twist. But I didn't want to leave the car apart and just put it back.
And, since I already have an appointment at the dealer for a new driveshaft while I was still in warranty, I just texted them that I also need upper strut bearings. Maybe after the dealer R&R's the struts again (I am _not_ compressing springs ever lol) to replace the bearings, and does the alignment after, it will be fine again?
Keep you all posted. This was an annoyance I had not planned on.
Then there's this, but I don't want to believe it:
https://mbworld.org/forums/w212-amg/...lls-right.html
Old Aug 7, 2022 | 11:36 PM
  #59
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
OEM the often quoted reassuring “Full Front & Rear ‘4’ Wheel Alignment” is in fact only Toe - directional adjustment. New car industries best kept secret
It is all to do with cost cutting and ever increasing speed of auto assembly lines.
We saw the need to re instate from the 90’s once again Camber and Caster adjustment to resolve costly, premature tire wear and steering pull issues. Excess edge load can also lead to ruptured side walls, rim damage.
See spoiler re Front & Rear Kits
A TOTAL SYSTEM FOR W212 E63, E63S AMG
Spoiler
Old Aug 8, 2022 | 10:35 PM
  #60
I.T. Guy's Avatar
2023 E63S Wagon
So it settled down around 3/8-1/2” at the front and I have an interesting phenomenon.
I set height again tonight measuring with calipers the distance from the bottom perch to purple adjusting ring.
When I make both sides exactly the same on the KW strut, the drivers side fender sits 1/4” lower to the ground.
passenger 26.5
drivers 26.25
both rings 19mm from perch.
Do I make the strut adjustment 1/4” higher on the drivers side to even out the fender to ground?
Old Aug 8, 2022 | 11:31 PM
  #61
Rehabguy's Avatar
E63S
I didn't do my own install for I wouldn't trust myself to put everything back the way it should go. I had a speed shop handle the install and alignment. After settling, I too had a discrepancy in floor to fender height vs how much thread left in the adjustable collars (the amount of thread left in either collar was equal, but the fender to floor height was off). In order to have the same Fender to floor measurements I lowered the front passenger side. The car hasn't exploded yet
Old Aug 9, 2022 | 09:12 AM
  #62
I.T. Guy's Avatar
2023 E63S Wagon
Awesone.
I think too much.
I tried 26” but personally prefer when the tire has an “even” gap in the wheel arch so cranked it back to 26 1/2
26”
26”
26.5”
Old Aug 9, 2022 | 09:25 AM
  #63
I.T. Guy's Avatar
2023 E63S Wagon
OK maybe somewhere in the middle I'm going to try 26 1/4"
LOL
Why did I give myself all these options.
In real life I prefer the 26.5-ish but in pictures man the 26" looks good.
Hah.
Old Aug 9, 2022 | 01:09 PM
  #64
Rehabguy's Avatar
E63S
This looks good! This is my definition of "OEM +" Welcome to the "Low life" lol!
Old Aug 9, 2022 | 06:27 PM
  #65
Rehabguy's Avatar
E63S
Just sharing the end results of driving around town for the past 5 yrs at this ride height
"That ain't gon' buff out"... lol!
Old Aug 9, 2022 | 06:37 PM
  #66
Rehabguy's Avatar
E63S
Quick!
Before it happens to you!
Old Aug 9, 2022 | 07:09 PM
  #67
ThreeSix's Avatar
G550
looks great! I have my KW kit sitting in the garage and have been wanting to get it put on. The install really doesn't seem too bad compared to other cars i've done in the past.
Is anyone here running the K-Mac stage 2 front strut top mounts? Im looking to installing these to be able to dial in/out some camber
Old Aug 13, 2022 | 10:23 PM
  #68
I.T. Guy's Avatar
2023 E63S Wagon
Question about the rear links
if I use them to lower 1/2” in sport+ does that mean when the car is off and decides to drop to its lowest setting is that setting is now 1/2” lower too?
Old Aug 13, 2022 | 10:47 PM
  #69
Rehabguy's Avatar
E63S
I had wondered about this issue in the past. I remember posting this question worded similarly and never got a solid answer. What I think is that you are not lowering the car for any one particular setting. That 1/2", in your case, simply applies to ALL modes.
Old Aug 14, 2022 | 07:07 AM
  #70
I.T. Guy's Avatar
2023 E63S Wagon
Thank you
I’ll have to take my spacers off then to be sure while testing to not accidentally have the fenders mashed.
I’ve had the wheels on and off so much I feel like a pit crew!
Old Aug 14, 2022 | 11:18 AM
  #71
kenneyd's Avatar
poop
The manual says that there are three height settings, I've only been able to find two basically comfort mode is about 1/2 to 3/4 in higher.
Sport, sport Plus and parking mode is all the exact same height.
I lower my car to the height I want in the lowest setting if that makes sense
Fast forward to about 2min in my video
Old Aug 14, 2022 | 01:45 PM
  #72
I.T. Guy's Avatar
2023 E63S Wagon
My concern is once in a while it goes lower then parking and sport and I don’t know why.
Parking and sport ^^ how it sits most days and overnight too for days - this is my stock sport height.
But sometimes while filling gas at the pump or just randomly once in a while it goes this low. No leak not defective, just a tantrum?
And if I lower it 1/4” or 1/2” lower in the other settings then the times it goes this low again it’ll be bad news… I think. I can never replicate this setting when I want it lol. Or is this right on the bump stops and I’ll be ok?!
Old Aug 14, 2022 | 02:51 PM
  #73
Rehabguy's Avatar
E63S
As I reported in a different thread, my car actually sits higher PARKed than when I drive in S/S+. Other members replied to such comment stating it was not the case for them. Those who replied to my "findings" noted their cars sit at their lowest setting when in PARK.
"My concern is once in a while it goes lower then parking and sport and I don’t know why." is exactly why I hate the air suspension in the rear of this car. Not to mention it some times looks like one side is slightly higher than the other.
I would love to see a full coilover solution for these cars enabling a "delete" of the airmatic BS and the in cabin ride dampening select. Set your ride height with spanners and be done.
Old Aug 14, 2022 | 06:18 PM
  #74
I.T. Guy's Avatar
2023 E63S Wagon
Yes! I’ve been measuring the height multiple times a day all four corners and it’s just all over the map even keeping the exact same shock and transmission settings; even the radio station lol. And as you pointed out, sometimes it’s uneven side to side up to 1/2”.
I don’t want to die at high speed from tires shredding on fenders because it’s a full moon and “Christine” decides “just a bit lower today”.
I just adjusted the fronts down more and they change height too depending what the rears are doing - not physically themselves but the fender to ground just because everything’s connected.
I’ll fiddle with the links one day soon I hope, still trying to nail down the fronts.
Old Aug 14, 2022 | 06:37 PM
  #75
Rehabguy's Avatar
E63S
