CEL 2015 E63s
Old Sep 8, 2022 | 12:03 AM
lgnd64's Avatar
E63s
CEL 2015 E63s
Hello Family
I am getting the following codes
P0368
camshaft position sensor b circuit high bank 1
P0303
cylinder 3 misfire detected
P0307
cylinder 7 misfire detected
i have change all spark, coils and camshaft postion sensor but problem still exist
i have no oil in the wire harness
What can be the issue?
Old Sep 8, 2022 | 11:47 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
Did you check the magnets
Did you check the 4 magnets. Check those also. both banks have a MF, check intake boxes piping double check those connectors.
Was their a MF before the plug change.
Old Sep 8, 2022 | 02:21 PM
lgnd64's Avatar
E63s
I was getting MF but no CEL came on. One day the CEL flashed and when I restarted the vehicle, it went away. I changed the 2 magnets on the left (Bank 1) and it still showing the CEL and errors.
Old Sep 8, 2022 | 05:20 PM
Mojo20032004's Avatar
2014 E63S
Check for oil in harness connection. Might be having the oil running down the harness and eventually into the ecu
Old Sep 8, 2022 | 06:19 PM
lgnd64's Avatar
E63s
Yes I check the connector to the camshaft sensor and magnet. I also change all 4 of each. I did see some oil. But no oil in the ECU
Old Sep 8, 2022 | 06:38 PM
2014 E63S
Did you clean all 4 cam connectors and all 4 magnet connectors?
Old Sep 8, 2022 | 06:47 PM
lgnd64's Avatar
E63s
Yep sprayed it and allowed it to dry
Old Sep 8, 2022 | 09:55 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
camshaft code...
Camshaft code and misfires with:
New plugs New coils New cams sensors
​​​​​I am thinking the misfires are caused by timing issues that point back at the camshaft code being higher priority.
What scanner are you using to read your ECU codes?
How many miles are your chain tensioners?
Did you have a look at your LTFT: how far negative?
Old Sep 8, 2022 | 10:52 PM
lgnd64's Avatar
E63s
I am using a iCarsoft MB 2.0I don’t think the chain tensioner has ever been changed. The car is 65k miles and i bought it at 63k miles
LTFT B1 is 3.9%
STFT B1 is 0.0%
LTFT B2 is 2.3%
STFT B2 fluctuate from 0.8 , 3.1 , 2.3, 4.7 percent
Old Sep 9, 2022 | 01:00 AM
LTFT B1 is 3.9%
STFT B1 is 0.0%
LTFT B2 is 2.3%
Good for you: your FT are looking healthy.
Both LTFT being slightly positive certifies your ignition as good. It's not starved for fuel.
To me this leads to faults being timing latencies....
You've replaced VVT solenoid and cam sensors then what's next...?
-- At less than 70k, I dont think your VVT Gears pins are worned out yet.
-- That leaves us with bad chain tensioners.
The good parts you've replaced so far are already working to preventing issues: no problem!
Old Sep 19, 2022 | 08:33 AM
lgnd64's Avatar
E63s
Issue fixed!
Hello
I ended up having to replace the spark plugs again with the ones from the dealership. Problem went away
Old Sep 19, 2022 | 07:06 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Hello
which plugs did you used that three these codes?
Old Sep 19, 2022 | 09:09 PM
lgnd64's Avatar
E63s
CEL 2015 E63s
i used bosch
