Openport Xentry Quick test
Old Nov 13, 2022 | 10:04 PM
atgordon's Avatar
E-63 AMG
About a year ago, I purchased a pre-loaded SSD laptop 360GB hard drive from Aliexpress, that was preloaded with Xentry (as well as Vediamo, DTS Monaco, EWA, DTS Venice) as well as EPC (parts) and WIS/ASRA (repair) info. Cost $130 supplied with a Tactrix clone ODB to USB openport adapter and USB cable. Once the hard drive was installed, I had to activate Xentry via a remote session using Teamview to allow configuration and activation of Xentry. Once completed, everything was working ... the Tactrix clone failed soon after, and so I purchased a genuine Tactrix openport unit from California (about $200), and everything has worked well from then onwards.
Since then I have used Xentry to monitor any quirks that occur with my 2010 E63 AMG. I have played with Vediamo and Monaco, but they are way beyond my capability to use (I did get Monaco to connect). EPC and WIS are really helpful (although I did have both from an ebay vendor). I have put together a Youtube video on using the Xentry to check my car - the QuickTest that the dealer techs run when you take you car in (my very first attempt and video editing, so very choppy): you can
The Xentry version supplied also has full access to all restricted features, so changing of factory parameters is possible (I am not confident to do so yet!), but I'd like to set the headlights to the European "follow the steering" setting (not allowed in the US). Suggestions?
Old Nov 14, 2022 | 07:20 PM
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
Since then I have used Xentry to monitor any quirks that occur with my 2010 E63 AMG. I have played with Vediamo and Monaco, but they are way beyond my capability to use (I did get Monaco to connect). EPC and WIS are really helpful (although I did have both from an ebay vendor). I have put together a Youtube video on using the Xentry to check my car - the QuickTest that the dealer techs run when you take you car in (my very first attempt and video editing, so very choppy): you can view the video here.
i believe @kenneyd made YouTube vid on this, exotic car garage?
