Trade a 2016 Chevy SS for an E63?
My M278 and M157 were both fairly well-built with the exception of a few questionable plastic parts (turbo coolant lines). There are little nits here and there but big picture they're pretty reliable given the amount of HP they put out. Cost of ownership will be much more palatable if you can do your own maintenance. If the engine goes boom it'll be very, very expensive so most have 3rd party warranties for peace of mind.
You'll probably get a lot of biased responses here - no surprise - to go for it. But they are great cars that pull and sound amazing stock, and really rip with a tune. Just gotta be prepared to pay to play.
I was talking to a friend of mine, who likes German cars also, and he told me he doesn't think it is a good idea to get rid of the SS for an E63 of this age because of all the bells and whistles and just too much stuff to break. He thinks I'll be in the same boat as with the SS just different things, which was a main concern of mine. What has really worn me down with the SS is just the things that refuse to go right or be fixed and stay fixed. I can deal with maintenance and repairs but when I spend thousands of dollars to fix a problem and it doesn't fix it or it goes away and comes back worse a year later, that is just beyond frustrating. I can fix everyone else's car, but I can't fix this one. The parts availability is also another issue I have with the SS and from my past experience, the German brands don't discontinue parts like GM does. That may no longer be the case but a coworker of mine has mentioned that many times about how he has no problems getting parts for his older German cars. I'm basing my desire for this car on my experience with my C55, which was a pretty great car from an ownership view. I did go with the C class purposely so it had less things to break but that isn't the case any more with the new C class since it has the electronic suspension and all. The E still has more but not as much more as it did in 2005.
I’ve wanted an E63 for a long time but maybe it just isn’t meant to be. I can’t afford anything newer to replace the SS that is equivalent (or better). The prices on cars these days is just insane to me anyway. The last two Mercedes I bought both had a full year of warranty left and it was nice to have that safety net before I was on my own. A 2-3 year old E63 will easily be double what the SS is worth.
That’s a lot of out of warranty maintenance money…
- I am running LiquiMoly MolyGen but it's unclear if this is really buying me anything. PO ran whatever the dealer has for 98k at ~10k intervals. So if that harmed the engine, that damage has already been done. Inside the oil fill is clean as a whistle. Do 5k intervals. Easier on timing chain and a POSSIBLE contributor to cylinder scoring (DI abrasive nano-particles, or at least small ones)
- Watch fuel pump duty cycle. Tasos talks about this. Obviously the goal is to avoid a lean condition. And it may be advisable to replace a pump that is wearing out before it fails.
- Keep the ignition system healthy. I have plugs and coils in a box ready to go. I am technically not due but just need to make the time. I suppose scoping the cylinders gives you some warning but realistically all you would be doing is selling the car before catastrophe, if you really believe we understand how this process works (i.e. how much scoring is "fatal" and what the timeline to failure actually is, vs running like that for 80k). I'd like to think an engine with relatively low oil consumption has at least a baseline level of good health.
- Watch injector adaptation values. I haven't looked into this much but plan to. Replace suspect injectors or replace them all?
- Walnut blast intake valves. It's costing power, smoothness and fuel economy. And stressing the valves/valve guides. Bad all the way around. It's on my list but no clue what my real plan is here.
- Keep an eye on wiring harness oil wicking. There are some areas that aren't as commonly discussed but the goal is to keep oil out of the ECU. It's an expensive item to replace, and can destroy the engine by using the incorrect parameters.
- Leave the stock engine tune. I am open to a TCU tune "someday."
- Blackstone UOA
- Don't romp on it until the oil is warmed up
- Monitor for coolant loss periodically and immediately investigate all unexplained losses.
These things aren't totally insane to watch for/correct for and I think they are real.
- Blackstone UOA
Has anyone done it? Has anyone scoped the motor to see status?
To me the list was "things that could prevent a lean condition, piston damage or cylinder scoring." I did not address the mystery seal behind the timing cover. But that's why I put UOA on the list. Keeping tabs on oil condition and contamination at the end of the 5k interval will probably catch a lot of latent issues before they become fatally obvious.
I think mystery timing cover seal is production based pre 2015. Not 100% though.
On the gasket/O-ring thing, mine is a 14 so I guess I have to worry about it. I plan to do a Blackstone UOA on this car when I am due for my next oil change.
I guess I should have added to monitor coolant levels in general. Unexplained coolant loss MUST be investigated immediately on these.
In the past 5 years I’ve bought and sold many cars without losing my *** (crazy used car market makes this possible) and this includes several V8 Camaros, Mustang GTs and C7 Corvettes - all with manual transmissions. A 2015 Peacock Green Metallic SS M6 tranny was my favorite of the lot. What a car! The killer on it for me was the outdated infotainment system. I posted some details on the SS forum - and the admission of failure at the end - of how I tried to swap in a Pioneer 9” high-def screen and audio system to overcome my main objections. I achieved 90% of what I wanted to do, but…
Over the years I also serially bought BMW sedans and coupes - all with V8’s. The last few BMW’s (2019 M550i, 2015 650i x drive, 2017 X5M) were really something else. After realizing just how great the V8 and suspension was stock in each of these, I focused on getting all the options I wanted. HUD, Night Vision, B&W Diamond sound system, etc. I retrofitted the complete Night Vision system onto my 2015 650iX and coded it to work just fine. Not a project for the faint of heart. I also did the Dinan intercooler mod to achieve M-level power from the 4.4.V8.
Now to my latest car - a 2016 Mercedes S550 4Matic Coupe. I’ve followed the Mercedes V8 (and V12) cars for some time and it was hard for me to really understand the distinctions of what the various models offered, apart from a big V8 NA or twin-turbo engine. I thought I’d land on a 2014 C-Class coupe but then read that Mercedes dropped that in favor of introducing the S-Class coupe in 2015. Well, it took me no time to remind myself and appreciate that the S Class is the pinnacle of Mercedes models, so that was what I was after. So a Model C217 it would be, but S550 or AMG 63? I decided that for an older car, the non-AMG might be a better choice for this, my first Mercedes, as I have no perfect way to know just how it was treated or maintained beyond CarFax and dealer service records.
3AM out at the farm! Matte white with dew and moon glow…
In sunlight the Designo Cashmere Matte paint just stuns me - wow! There are no “dead buttons” in this one: options include the HUD, Night View Assist Plus, standard Burmester (not the 3D) audio
Coming to me with less than 30,000 miles, this car has everything I’ve come to want. I’ve not seen an S coupe with the Burmester 3D top-end audio, mainly in the S sedans. I like the sound quality in this “quiet-as-a-tomb” S class interior. However, some muddiness is there so this one will get all the speakers replaced with drop-in Focal flax drivers. Focal flax is not cheap but it has been my go-to in the last few aftermarket car stereo systems I’ve done. Then I’ll have a critical listen and decide whether or not to install a sub box in the trunk. I have one each of a JL Audio 10W3 and a 12W3 already in appropriate-volume boxes, either of which will fit in the trunk. I’ve done hundreds of car audio systems and this is almost trivial for this car with the battery and the Burmester amp both accessible behind the trunk panels. Pins 3/15 and 4/16 from the Burmester harness seem to send the signal out to each of the firewall-mounted front bass woofers. I’m not sure yet whether to tap just one of the those channels or tap both and sum them for my JBL Club 600 small form-factor sub amp, which handles speaker-level inputs and turns on automatically when it senses them just fine. In general, once you’re ready for an initial sound check post-installation, you turn down the factory bass settings a few notches thereby converting your “front bass” 8” drivers into mid-bass drivers, what they should be after all. You use a white noise noise generator and a proper “listening” device to play and measure the signal inside and also your ears to dial in just enough low bass from your dedicated subwoofer amp to achieve a true full range audio spectrum without boominess.
I also bought the VCI and recommended Lenovo 230 laptop per BenzNinja and I plan to code in several desireable features. As for engine tuning, RennTech, RaceChip and MW Mods (a forum sponsor here?) all seem to offer either OBD2 or piggyback tuning support. I have used HPTuners before on my GM V8 cars but there seems to be a dearth of tune repository or knowledge base support for the S550 non-AMG 4.6 V8 over at HP Tuners on their forum site.
Anyway, I’m glad to have finally joined the MB tri-star world and I look forward to driving and upgrading this ride.
