Could A Bad Alternator Cause Misfire?
If they do not match it itt looks at what cylinder was supposed to fire at that time and throws up a the check engine light.
Now a bad alternator (or anything drivenby engine Serpentine Belt) can cause additonal uneven torq demand from crank.
The crank sensor sees these as misfires since crank was slowed down for quick bit and the wave form does not match what it expects
TO test - clear misfire codes.
Remove serpentine belt
crank engine and watch temps and pressures etc but run for a min or so and see if it throws code for misfire.
IF not maybe something with pulley on front needs some love sticky bearing in idler pulley or tensioner spring is too soft and worn now so belt bounces.
Alternator going out and has bad spot or soemthing.
