Cooling fan always on and high speed
Old Jun 11, 2023 | 06:37 PM
laitho001's Avatar
Mercedes E63 2010
Hi my E63 2010 fan always on even when I shut off the engine and on high speed always so what’s the problem ( and did anybody know where’s the cooling temperature sensor located please )
thanks all
Old Jun 13, 2023 | 07:23 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
thanks all
It is normal for the fan to stay on in high mode after shutting off engine for a couple to a few minutes when it’s pretty hot out or if you were doing some hard pulls prior.
Old Jun 14, 2023 | 10:47 PM
laitho001's Avatar
Mercedes E63 2010
nah it’s always on even when the engine is cold at cold start the fan turn on on high speed and never shut off till the battery dies
Old Jun 15, 2023 | 05:53 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
coolant temp sensor (you're going to hate replacing this)
-or-
AC pressure switch
Both are scannable things once you get a decent scanner. not an AMG specific or even a Mercedes specific thing. It's just annoying car things from newer cars that run off 200+ sensors
Can't tell you which one it is cuz I can't tell you how you broke it. Gotta just read data to pinpoint what it is, aka grab a good scanner that reads make-specific data.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
