Oil pump solenoids
The current theme is to produce controls that simulate old engines... Once you understand the playcards, you can peel off the onion to a level you are more comfortable with.
MB electricals are a contrasted mix of the best technologies. Treat your car to a clean regulated voltage. It's the basis for all 46 computers to tic.
Performance & longevity are trade offs. When you reverse course, you may encounter both combined such as in this amazing thread.
Last edited by CaliBenzDriver; Dec 25, 2023 at 09:36 PM. Reason: VOLTAGE is to computers what OILING is to engines...
Anyone has this one in their cars?
It seems to be used on turbo engines ( fitment/applications section), and you can see the location in the diagrams.
I assume those engines should be able to read it via Xentry -> able to code it to the cluster?
If that is the case, then why not just find an oil pressure sensor with the same thread and run either an electric or mechanical gauge?
Too bad the m157 filter housing doesn't permit fitting a pressure sensor/temp sensor housing between the block and the filter (like I had in my Subaru).
Going to try and hookup a sensor here myself and figure out how to mount a stealth gauge in the cabin.
I’m thinking the easiest way of looking at oil pressure will be via a modified cap. Because the pressure variance has been removed, it should be a matter of looking at the gauge under the hood at various temperature and rpm levels. Pressure should follow rpm - drive some to get it nice and warm, and then have a helper on hand to rev the engine to specific rpm levels while you record the data at different rpm points. This can all be done in your driveway, on the side of the road, etc. Repeat the test post-different driving conditions. Using this method, you’ll be able to map the oil pump’s capabilities.
If displayed oil temperature is close to actual, there really won’t be much of a need to monitor pressure constantly either.
EDIT: Looks like it's an M12x1.5
A forum member with an S63 (w222 forum) saying he did the disconnect and received a CEL afterward. I’ve got 250 miles on mine post-disconnect and no CEL for the oil control circuit. I commented asking if maybe something else triggered the CEL… haven’t looked for a response yet.
There was a commenter on Kenney's video of the mod saying he was a MB tech. He stated that on a lot of cars this code is now updated to throw a CEL. So he may have a newer car and has had MB update his firmware knowingly or unknowingly, because if they're anything like BMW/BMW Motorrad, they will update your firmware anytime you take it into the dealership for service without notifying you.
That, or indeed he does have an issue or maybe his solenoid was indeed stuck in the position we don't want it in and it somehow caused some other incident. No idea unless he gets a code reader or XENTRY on it.
I know when you join the @BenzNinja club that one of the things Peter will do is to make a copy of your existing firmware and settings. I haven't asked him to do that yet, but I will just to have a copy. I also have a tune where I made a factory copy of the factory file and sent it to the tuner ( @VividRacing ). They make their adjustments and send the tuned file back. So, I can always restore the factory or tuned files if necessary (I hope).
I got a 14' E63 S and I disconnected the plug today. After it, we went for a 100-120 km drive with family and everything is good. My brother have a 17' S560 with the M176 engine and I want to ask that is that engine have the same "plug"/solenoid?
Thanks for the answer!
Tom
