URGENT!!!E63S Random Misfire
good fuel injector
good ignition plug + COP
This is edging towards low cylinder contribution.
-1- Read LTFT idle fuel trims for laggy LEAN
-2- Borescope #8 with piston lowered.
What type of oil are you running that needs you to stop for cool downs ??
and no its not injectors problem or ignition coil or fuel pressure or spark plugs
today i changed engine harnes and again the same problem the last thing im gona try on monday its the ecu
-- You do have known good ignition parts
--->So you have a fuel delivery Issue that causes a LEAN MISF.
Double check your fuel side real well:
- low pressure
- high pressure at idle
- high pressure under acceleration
- LTFT's at warm idle
If above is good then a full chassis fault scan could give us background story from other faults:
- Oily ECU
- Low voltage yoyo faults
- Missing sensor data
It's all about casting a net to collect evidence of issues on hand.
Random weak mixture fits LEAN trim perfectly.
> THOUGHTS....
This issue may well be what tanked your engine under heavy load conditions in the first place.
Did you have rod bearings issue or what was wrong that had to be repaired??
NO italian tune-up until you engine has solid balanced contributions.
Else couple hot cylinders pay for all the lazy ones.
> Hot question worthy of interest:
what is the easiest way to measure that all Cylinders Are Evenly Contributing well +/- 15% ok.
Having good tips could prevent wear and REBUILDS.
- low pressure
- Oily ECU
> THOUGHTS....
So this is my ecu could be a demaged ecu because of the water inside?
i cleaned it the water corrusion and the ecu is really clean now but the problem its still there could my ecu be demaged
was the ecu opened and poorly sealed for tuning purposes (back when they had to open it to tune it)? Or was the car exposed to water damage hence your major rebuild?
unprotected PCB shows oxidation short circuits... cleanable!
The location and landscape makes this cleanable with isopropyl alcohol + tooth brush.
Feel free to brush on the missing conformal coating except where heat pads are located.
ROHS failing solder joints...
These heavy joints are not burnt into "PCB charcoal" PCB yet but right around the corner.
This shows why pressed pins are used to prevent failed solders. Instead we get failed pins oxidation... I found that combining the mechanical hold of pressed pins + electrical solder transforms CAN bandwidth.
this cooling pad needs to be restored
Component heat is transfered to the case heatsink through this conductive material. It needs to put back. - It's much like RTV sealant squeezed between 2 surfaces: don't use too much paste that will then spread all over.
++++ WHAT CAN WE LEARN.....
This liquid damage is not petroleum.... closer to H2O water. About a quarter tea spoon amount.
It came from somewhere... through the connector!
So inspect your connector pins on both male/female sides. Expect crusties.
NEVER HOSE DOWN ENGINE CLEAN!
The MB connector seals have a limited expiration date after which wires move liquids by capillarity.
It's likely crusties were also on the opposite side between the connector legs.
These Bosch electronic circuits are fairly rugged design. They can handle a whole lot of abuse meaning limited crusties are not terminal conditions once cleaned.
++++ SCANNING FOR THAT.....
We don't want to crack open these working modules without solderless issues.
When scanning we can expect bogus results to alarm us.
tomorrow i will try the cranshaft sensor and the new ecu and update you guys
