RECARO seats retrofit complete
Swapping them in dropped about 70lbs compared to the OEM power/heated/ventilated seats with side airbags, which felt like boat anchors by comparison.
All SRS-related functions are fully coded out using DAS/Xentry - no airbag lights, no fault codes, no warnings and no need for resistors.
I left the factory seatbelts in place to keep things as OEM as possible, just waiting on a few bolts to finish securing them and it should good to go.
Super happy with the feel and look of these seats, makes the driving experience much more exciting!
Is driver seat with active side bolsters heavier than passenger seat?
This is great update to your car, most of us who are "sporty" find simple manual buckets such as your Recaro leather buckets perfectly comfortable.
fantastic job dude. I have a set of 213 recaro seats that are 25 lb lighter each about . I wanted these but didn’t want to lose the seat functions. . Your setup looks killer .
The stock seats were comfy for sure, but they sat way too high for me and felt very bulky. The ventilation was hardly noticeable and I wanted to update the look for true bucket seats similar to the black series.
The Recaros hug you into place and sit much lower, gives it more of a drivers feel to it.
Yeah the Recaro's are surprisingly comfy and they lock you into place.
Cifdig,
Are W213 E63 AMG front seats "plug-n-play" swap into our W212? And 25lbs weight savings each?
Thanks, curious, because they retain OEM look, although do not save nearly as much weight.
