FS: OEM Front rotors / Timing chain tensioners / Trans service kit NY/NJ/CT/PA
I can meet up for the sale in the Orange County NY area and can meet you half way if you're coming from a reasonable distance. I will not ship these parts!
OEM Front rotors and pads with sensor $1,000
OEM Timing chain adjuster kit with hardware and sealant. Also comes with OEM belt and NGK spark plugs $580
OEM Transmission filter, gasket, green level plug, hardware and sealing washer. Includes 7 qts of LiquiMoly fluid $200
If you buy everything I'll give you a discount. I take cash only at the time of sale.
I also have a Eurocharged stage 2 tune with the handheld floating around for my old car. I'll try to get the last 8 of the VIN and see if you bought it!
