Spark Plug part number and fitment.
Old Mar 14, 2026 | 09:20 AM
dustinN's Avatar
09E350, 07E63, 13CLS63
Hi guys, I'm about to change the spark plug on my 13 cls63 wth 50k miles on it. I found a couple different part numbers Q-4-15-0038 for around $18, and 004-159-81-03 fis about double the price. I'm not sure about the fitment of the Q-4-15-0038. Has anyone experienced with this? Thank you all.
Old Mar 15, 2026 | 11:10 AM
streborx's Avatar
Top Answer: 1
G550
FCPEuro lists the 81-03 plug as Bosch/MB-OE and MB at $12 and $39 respectively. I'd call and ask if there's a difference.
Old Mar 15, 2026 | 01:01 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
I too wonder if it’s exactly the same
Old Mar 15, 2026 | 01:42 PM
streborx's Avatar
Top Answer: 1
G550
I bought a set of genuine MB spark plugs and they had laser engraved NGK numbers on them, but I'm not sure they are same as NGK branded plugs that are listed as compatible. MB insists direct injected engines require their spark plugs to be indexed. The MB plugs I bought were all identically threaded such that when seated, the ground electrodes are in a prescribed orientation. FCPEuro can probably tell you if the Bosch and MB plugs are one in the same or if there is a difference. For me, a $2 difference between MB and NGK wasn't worth thinking about. With your MB plugs being 3x the Bosch plugs, I'd spend a few minutes on the phone.
Old Mar 16, 2026 | 12:50 PM
dustinN's Avatar
So I made the call to FCP as your suggestion. I'm going to order the Bosch. The coil is even more crazy expensive. Bosch: $57. MB $91. Do you recommend to replace those as well?
Old Mar 16, 2026 | 01:26 PM
dustinN's Avatar
Read some comments about the problem with indexing and gap so I decided to go with Genuine MB plugs. The coils are the one I have more concerns because they are so expensive.
Old Mar 16, 2026 | 01:48 PM
AlexMonroe75's Avatar
For the newer M256 engines (2021+), you want the Bosch FR7NI332S — OEM fitment, no
Old Mar 17, 2026 | 10:28 AM
streborx's Avatar
Top Answer: 1
G550
Unless you're receiving misfire codes, or unless there's physical damage, I'd stick with the originals.
Old Mar 18, 2026 | 11:28 AM
dustinN's Avatar
What tool is used to remore the plug wire connector? I broke the clip on the top the plug. I broke 3 of them. I'm afraid that with vibration, it wont keep the connector in place.
Old Mar 18, 2026 | 12:13 PM
streborx's Avatar
Top Answer: 1
G550
There's usually not a special tool necessary, but there are a variety of locking mechanism designs. Usually, there's a place that needs to be compressed to release a locking tab. Other times, the locking tab requires a piece to slide, and sometimes both.
Old Mar 18, 2026 | 12:24 PM
dustinN's Avatar
I finally figure it out. Its too late, i broke 3 of them. It seems to hold the wire connection ỉn place but not very tight. Will replace if there is a problem. Thank you.
Old Mar 18, 2026 | 02:21 PM
dustinN's Avatar
OMG, after inserting the spak plug, the socket got stuck inside. Tried to insert the extension but it wont snap back on because cannot see it. Tried to take picture, see it there but unable the snap the extension back on. whatever a disaster!
Old Mar 18, 2026 | 06:38 PM
dustinN's Avatar
Got it out. Stop at 7 & 8 for today. Will restart fresh tomorrow. Thank you all for helping.
Old Mar 18, 2026 | 06:47 PM
streborx's Avatar
Top Answer: 1
G550
That happens to me all the time, and probably to everyone else too!
Old Mar 18, 2026 | 09:26 PM
dustinN's Avatar
Any tips for #7 & 8? No room to work on.
Old Mar 18, 2026 | 09:27 PM
dustinN's Avatar
Old Mar 19, 2026 | 05:07 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Theres plenty of room is you use the proper extensions and swivel sockets….
Old Mar 19, 2026 | 09:41 AM
dustinN's Avatar
So i used this socket & entension. I managed to insert ỉn but it wouldnt snap on the plug. And now its stuck, i cant take it out. Can i spray by the connected join to lubricate? I am trying to seperate the 2 pieces and take out one by one.
Old Mar 19, 2026 | 05:43 PM
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
Yep, gotta use a swivel top socket. Might need to mangle that heat shield to get that loose.
Old Mar 19, 2026 | 07:37 PM
dustinN's Avatar
Got it done, finally. Its the tough job. I warmed the engineb up a lttle bit so there was no problem to pull out the coils. I see oil on the old plugs, do i need to worry about this?
Old Mar 20, 2026 | 03:34 AM
Baltistyle's Avatar
boroscope the cylinder, figure out if oil is from intake, or stuck rings….imo, a proline engine flush at each oil change will help start to clean it up. Do you have any smoke on start up or under light or heavy acceleration?
Add a pic of the plugs for us to see.
Old Mar 20, 2026 | 06:47 AM
juststeve's Avatar
2012 E63 Wagon
don't remember which combination of sockets and extensions I used for this job. none of these are big money when compared to a visit to the MB service center.
Old Mar 20, 2026 | 07:45 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
For me, the big thing was the Mercedes tool for spark plugs (my local shop lent to me). It has the elbow built right in - it was like magic.....
https://www.fcpeuro.com/products/thin-wall-12-point-14mm-spark-lisle-63080?ads_cmpid=21626320283&ads_adid=166630207859& ads_matchtype=&ads_network=g&ads_creative=71092765 3133&utm_term=&ads_targetid=pla-2341526632000&utm_campaign=&utm_source=adwords&utm _medium=ppc&ttv=2&gad_source=1&gad_campaignid=2162 6320283&gbraid=0AAAAAD3np3VXkpBqBaLaJ0up4JE0VecXW& gclid=Cj0KCQjw4PPNBhD8ARIsAMo-icyVt4V9b8q_IRxKvTJOoSfkA1JYpvF5LN0Sl60FSlZe_WN6iM hRBnIaAiuVEALw_wcB
https://www.ecstuning.com/b-genuine-mercedes-benz-parts/spark-plug-wrench/278589000900/
Old Mar 20, 2026 | 08:44 AM
dustinN's Avatar
I just checked the plugs again, only one is a litlle wet. I just don't remember what cylinder. Too much work to remove every single one to boroscope. I don't see any leak from valve cover. Will do the liquid moly pro-line engine flush now. Thank you for your help.
little smoke when startup but its been like that since the đây i bought the car.
Old Mar 20, 2026 | 06:12 PM
Baltistyle's Avatar
just use it according to the directions. I’ve used it for my past couple oil changes/flushes and still get some debris. I had two wet cylinders. There should be zero smoke on start up and zero smoke under your first heavy acceleration of the day. Smoke on first start up often points to a valve seal. Smoke with first wide open throttle often points to blow by. .
generally, the cylinders to worry about are the ones closest to the turbos. However, that was not where my stuck rings were.
this is after 5k miles since I inspected and saw my two wet cylinders. I did an engine flush at that point, had my valves cleaned, changed my oil twice and then flushed again a week and a half ago. Looking in my oil cap has always been spotless. The assumption is that this debris is coming from perhaps the valve train, or more realistically the rings being slowly cleaned. If you read my story, I always do 3000 mile oil changes, but I was using lots of Ceratec and I think that contributed to my problem. I’ve not used ceratec since. This is the most debris I’ve ever seen in my filter.
