Passenger Bi-Xenon Keeps Failing
Old May 4, 2026 | 08:20 PM
MBShepherd's Avatar
2012 E63
Hey all, got a "Check right low beam" on my dash, checked to confirm the light was out. Ordered 2 new lights and replaced both sides. Confirmed passenger side was working again, took a quick drive to warm up my new oil and got the same error on my dash and noticed the passenger light was out again.
Did some looking around on here and online and it seems like it could be the ballast, the ballast connector, or a bad wire / failing shielding. I did a visual inspection inside the light housing and everything looked in good condition. Hoping I don't need to pull the bumper to check/swap the ballast, was wondering if anyone had any ideas on what else it could possibly be or some easier things I might be able to check first.
Old May 5, 2026 | 06:27 AM
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
Ballast swap is not as simple as plug and play. You'll need to recode new ballast in videamo.
Yes, You'll have to pull the bumper and remove the lights to get to the ballasts. All things considered, you'll probably have to go that deep to rule out everything else anyway that could be the cause.
Old May 5, 2026 | 03:59 PM
MBShepherd's Avatar
2012 E63
Thanks for the reply... didn't even consider it would need recoding.
Might have to take this somewhere because I haven't got Xentry or Videamo setup yet. I'll report back.
Old May 5, 2026 | 04:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Two thumbs up on replacing both sides at the same time: smart!
If you want a quick tip is to use your MB scanner yo interact with your light control.
I am not exactly familiar with your HID ballast, it may be controlled by F-SAM or provide its own networking.
See what module records the fault... its the one that detects it. It may help confirm suspicions...
Headlight ballast modules don't care for soaking HID or LED... if you see evidence of that get a new pair.
Soaked MB electronics feature unprotected circuits: replace!
