Lowering / Stance
Old Nov 16, 2017 | 01:08 PM
LBCWT's Avatar
'18 Mercedes-AMG E63S
Lowering / Stance
I'd like to lower my '18 E63s a bit and aggressive (new verb) the stance a little bit w/ some wheel spacers.
Any product recommendations?
Old Nov 16, 2017 | 01:22 PM
bobblehead's Avatar
go fast grocery getter wagon
http://loweringmodule.com/next-gen-l...sion-code-489/
Old Nov 16, 2017 | 01:38 PM
LBCWT's Avatar
Thank you! I will check that out!
Old Nov 16, 2017 | 01:46 PM
bobblehead's Avatar
No mentioning of how much drop it can do with this module. If you can wait, then there should be other brands out there with pretty well the same kind of lowering module.
Old Nov 16, 2017 | 05:32 PM
LBCWT's Avatar
Company replied and said:
"The E63s only uses air suspension in the rear so the module would only lower the rear of the car. Therefore it would not be a good solution."
Renntech said:
"You got air on all 4 corners."
Old Nov 16, 2017 | 06:03 PM
bobblehead's Avatar
there are no literature out there to suggest E63s has air at the rear ONLY. Does not make sense at all, esp. how can a $100K car has two different suspension setup.
So, you should avoid that company completely
Old Nov 16, 2017 | 06:50 PM
Aamir_'s Avatar
2018 E63S AMG
The E63S uses airmatic all the way around. In Sport, Sport+ and Race, the car lowers itself by 0.6 inches all the way around, iirc.
Old Nov 16, 2017 | 08:47 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The W212 E63 had air suspension in the rear and traditional coil and strut in the front.
Old Nov 16, 2017 | 08:49 PM
shardul's Avatar
Those lowering modules are a PITA to install they will splice into to factory harness for the airmatic computer.
Just wait for a bit and lowering links will be available soon.
The ride height can also be adjusted via the STAR DAS computer.
Old Nov 16, 2017 | 09:54 PM
Vic55's Avatar
Administrator
Yes in all modes but Comfort, the car is dropped the amount you stated. In comfort mode the car drops the .6 of an inch once a certain speed is reached.
Im lowering mine the day I get it (if my tech is open) and he can just manually go under the car and do that. He did the same on my last few Air cars.
Old Nov 16, 2017 | 10:05 PM
Aamir_'s Avatar
2018 E63S AMG
Yeah, have some not so great roads 'round my neck of the woods, so I'm gonna leave her completely stock on that front.
Have you spec'd out a car yet, Vic?
Old Nov 16, 2017 | 10:32 PM
Vic55's Avatar
Administrator
My dealer is one of the top in the region so they got one of the "extra" Edition 1's sitting at the VPC. Apparently MB holds a few extra cars for the better producing dealers so ive decided to take an ED1 vs the white car I was gonna get.
Old Nov 16, 2017 | 10:44 PM
Aamir_'s Avatar
2018 E63S AMG
Ah nice one. I was debating ED1 vs my normal spec. Both were similarly priced, but I settled for the normal car. Comes in at the end of the month, been waiting almost half a year now!
Old Nov 16, 2017 | 10:59 PM
Vic55's Avatar
Administrator
I still think the car will sit high enough for almost all situations and Im hoping the ABC doesnt get anymore taut. Either way, the lowering process is easily reversed vs a spring or coilover swap.
Old Nov 17, 2017 | 12:13 AM
Ed99's Avatar
E63s AMG
So is the W213 E63s on air for all 4 corners or same set up just like w212 e63s?
Old Nov 17, 2017 | 06:56 AM
2 '02 S600's Avatar
2020 E63S4S
Air for all 4 corners on the W213 E63s.
Old Nov 17, 2017 | 10:38 AM
Ralcbah's Avatar
2018 E63S
Check out Renntech's new solution for this car. As shardul mentioned, for the W212 platform, the install of the Renntech DLM was 'something'. The new one for this w213 is super simple....ODBII interface. Looks great.
