Acoustic/comfort package windshield and tollpass
Old Dec 19, 2017 | 04:19 PM
Pingupinktu's Avatar
AMG E63S
Well apparently it doesn't work... it blocks the signal. We had to wave it outside of the car!
Old Dec 19, 2017 | 05:13 PM
Warehouser's Avatar
2023 S580 Selenite
We have EZ Pass in Houston, when I had my 15' S550 it had the same cutouts in the windshield and the sticker never worked. They offer a License Plate version of the EZ Pass that would bolt onto the top of the front plate using the top screw holes. Since I NEVER run a front plate, I plastic tie-wrapped the unit behind the front grill and it worked perfect. I am ordering a 18' S560 and plan on doing the same thing.
Old Dec 19, 2017 | 05:17 PM
Vic55's Avatar
Administrator
Mine worked from the inside here in Orange County, CA.... Must be the level of the transponder.
Old Dec 19, 2017 | 06:28 PM
2012 merc amg's Avatar
2018 S560
seems to work right near the base of the middle of the windshield about an inch up.
Old Dec 20, 2017 | 09:52 AM
24Hours's Avatar
2019 E63S wagon; 2016 Landrover Landmark
Dammit... I was wondering about that. Not 100% sure I'll get LIDAR system, but since all tolls in NY-area are now automatic (no booths) I have to run the EZ pass... I never put the front plate on the '14, but might need to do so this time around.
Old Dec 20, 2017 | 10:03 AM
AMG E63S
was traveling from pa to nj. It didn't detect the transponder the whole trip. The sign would show "No ezpass, toll unpaid" when I got in a rental on my way back the same transponder worked perfectly.
Old Dec 20, 2017 | 12:23 PM
2 '02 S600's Avatar
2020 E63S4S
Which one of the two spots did you have the ez-pass mounted to? I have mine up on the side of rear view mirror, haven't gone through the tolls yet with the car though.
The lower spot is what I have used for the 15 & 16 S550s my parents have and it works fine in the location. Wonder if the battery is getting low in the transponder perhaps.
Old Dec 22, 2017 | 06:27 AM
AMGBEASTMODE's Avatar
20 Lamborghini Urus, 2021 G63
My garage passes don't work through the windshield, it must be the type of pass.........
