Coolant temp gauge???
2018 E63S AMG
I have my left hand display set up using what I think is the Progressive style. On the right hand side sub panel of the left display there are a number of pages you can scroll through. One of them show tire pressure and engine coolant and transmission temp.
The other way that I've displayed it before is on the right display by going to vehicle then dynamic data then I think it was engine data, or maybe chassis data, one of those anyway.
I think it shows up in a couple other places, but those are the two that I've usually used.
1 Post
2018 E63s Wagon
I see the engine oil temp (oil can with a temp gauge through it). I also see the the coolant bar gauge at the bottom right of the progressive display. I was hoping for an actual number. Thanks guys!
2018 E63S AMG
Here's what I see (I should add, my build date is 10/10/17 and we've noticed that there are differences in some of the displays in earlier build dates):
In the "Classic" display the coolant temp is at the bottom of the tachometer gauge similar to how the fuel level is displayed at the bottom of the speedometer gauge. Also, if you pick "Service" as the secondary information on the left screen, there is a "Coolant" choice that will display the coolant temperature.
1 Post
2018 E63s Wagon
Checked it all out. The temp gauges are all just a bar graph. So strange that they offer so much information that is so useless. Yet.... coolant temp is essentially an idiot light. What are they hiding???
