265/35R20 vs 255/35R20 front tires
Old Mar 5, 2018 | 09:17 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
The diameter of a 255/35R20 tire exactly matches the 295/30R20 tire used in the rear. Why is the slightly larger tire, namely the 265/35R20 used instead. The reason that I'm asking is that I want to put the new Michelin Alpin tires on the car when the current oem pirrelli tires wear out.
The Michelin tires do not come in the 265/35R20 but do come in the 255/35R20 along with the 295/30R20. Would there be a problem using the slightly smaller tire for the front fitment?
Old Mar 5, 2018 | 10:39 PM
Bibenstein's Avatar
2018 E63S
Go to www.willtheyfit.com and plug your numbers in. A 30 aspect ratio on the 295 though will leave you with even less sidewall than the 35, be careful there.
Old Mar 5, 2018 | 11:29 PM
2012 merc amg's Avatar
2018 S560
The car will not handle the way it's meant to. Back end will be jacked up a little bit. I just plan on going with the same michelin super sports that came on the car when I need tires. Hopefully get at least 15K miles out of these ones, I'm at 4 K miles now, might be another couple of years.
Old Mar 6, 2018 | 10:02 AM
HBerman's Avatar
I am not looking to change the rear tires. They are already 295/30R20. My question was reducing the front from 265/35R20 to 255/35R20. The diameter and sidewalls of the 255 tire is within .05" of the rears. Not sure why MB is using a slightly larger tire for the front.
Old Mar 6, 2018 | 05:50 PM
nynd's Avatar
2018 E63S
I think it has to do with the added .2" in the sidewall. That little bit will most likely provide some added protection for potholes etc..
The 255/35 is an exact match diameter wise, maybe tougher to get in Pirelli and Michelin considering they are the two sources or speed rating issue.
