Edition 1 & Early E63S QI Wireless solution... I found one.
Old Mar 22, 2018 | 09:37 PM
SANDOVAL's Avatar
McLaren 12C Spider | Lamborghini Superleggera | Porsche 997.2 TT | Cayenne TT | AMG GTS
So I have been on a hunt for a QI wireless charging pad for the center console that would be close to if not OEM. The OEM solution was not an option. So I had to go and find an alternate solution. Here is what I found and it is only $19.99! This wireless charging pad fits perfectly in the charging spot in the center console. *Ashtray removed. It is actually slightly larger to the point where you have to give it just a little pressure to lock in place. Almost as if it were designed for the space. The USB cable is long enough to run through the console to one of the USB ports located in the arm rest console. Pad charges the iphone and it's secure in its spot! The pad material is also grippy so your phone will not slide around. The pad itself is ridiculously thin. It's perfect.
Best part it is a $20 mod on Amazon and you can have it in 2 days
https://www.amazon.com/gp/product/B0793TJ9YR/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0793TJ9YR/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
