F90 M5 vs E63s
Old Mar 29, 2018 | 05:48 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Originally Posted by limeypride
Coding is the (rather excessively technical) word used to describe a process in which you can activate features on your car that were otherwise disabled for compliance or regional/locale reasons, . . .
I want that! I really don't like that fact that our active headlight's are not fully enabled. Would really like to turn that feature back on.
It's my car, ought to be able to do what I want, within reason of course.
Old Mar 29, 2018 | 06:05 PM
bobblehead's Avatar
go fast grocery getter wagon
for MB, it seems to be more difficult to get it coded as there is the other thread that OP wants to get into the engineering mode which is supposed to enable / disable the car's features & functions (similar to bmw) without much success thus far.
Old Mar 29, 2018 | 07:40 PM
Vic55's Avatar
Administrator
Sylvain, the piggy is usually an early adopting tune where the ECU has not been cracked... I have never used one once in my all my years of tuning my cars. Im not saying its not safe but here is basic explanation from one of the tuners on the M Boards:
In a nutshell, a piggyback tricks the computer in order to achieve a desired result. It doesn't have direct control over engine operation, and it can not surpass certain limits/restrictions imposed by the factory computer. A proper tune is a much better way to go for the goal you have set.
A proper tune is as if the computer was programmed for the car to output those power levels from the factory without intercepting signals, etc.
Spacers will look good on the car but without the drop the wheels might look funny being so pushed out the fenders which will accentuate the gap visually. Supreme has tons of BMW spacers which I used on both my M5's and my F80 M4--- I think based on your pictures you could run a 15mm square setup (05x120 bolt pattern) and Supreme will let you test them out.
Old Mar 29, 2018 | 09:06 PM
AMG 17GT's Avatar
R Nine T
Vic, which tuner do you lean to on BMW?
Old Mar 29, 2018 | 09:13 PM
Quickburn7's Avatar
2018 E63, 2008 SLR DH, 2011 599 SA, 1995 F50, 2007 through 2011 GT3 RS
As always thank you Guys for the clear explanation . Removed the resonator today but it’s droning a lot need to find plan B!
Old Mar 29, 2018 | 11:02 PM
limeypride's Avatar
2018 AMG E63S
That's true in some cases but the JB4 is far from a solution born of compromise; it's mature and highly capable. As far as I know, it's responsible for the S63TU world record in the 1/4. The JB4 goes far beyond the piggyback norms that merely insert lies into the requested boost vs actual boost feedback loop... and the installation is more complex as a result--still user serviceable, though. In the vein of lending some personal-experience and, hopefully, credibility to this particular product, I tuned 2 x F10 550s, 3 x F10 M5s, 2 x F06 M6 GCs and 1 X5M all with the Burger products. The first 6 cars in that lineup actually used the very same box which was transferred from car to car.
The Internet is always the source--take a look for yourself, the JB4 is well respected. Vendors such as Dinan are far too conservative so many reverted to actually stacking the tunes--a little scary but the results speak for themselves.
Old Mar 29, 2018 | 11:07 PM
  #32
limeypride's Avatar
2018 AMG E63S
I've no idea if the new car even has it or if, perhaps, the legislation has changed and it's now enabled by default. Assuming not, you can usually find folks willing to do it for you for a fee. Or, if you're reasonably technical or willing to learn, simply buy the requisite OBDII cable, download E-sys (I think there's a license requirement still), research research research and off to the races.
I coded all of my own cars myself--the learning curve isn't that steep.
Old Mar 29, 2018 | 11:25 PM
  #33
Vic55's Avatar
Administrator
I use VF Engineering, its not going to win the internet battle of dyno sheets but I have tried several others and while they produce amazing numbers they can not sustain the type of driving I do on a regular basis. The heat soak issues with the M5 are very prevalent and while I had a tune(s) (no names here) it just couldnt deliver over and over as a **** star like myself expects LOL. EG: I would take my F10 M5 out (2013/2016) and rip it with tune 1 and 2 to about 150 mph and up and down the ranges in Cali heat circa 90 degress. But after 3 plus hard runs the car would heat soak it would become a normally aspirate 4.4 engine until the intercoolers did their work. The F10's have terrible cooling. But with VF I could run the car over and over; it may not make the peak hp that others did but it was daily usable tune that delivered over and over. Where I live I have the luxury of being able to really open my cars alot and for stretches at times that exceed 15 miles. So maybe these heat soak ECU tunes might be good for those in traffic but not for me.
I also used VF on my F82 M4.... prior to that I used OE for my E63 M6, E92 M3, and E46 M3. VF is probably better known for their R8 tuning and superchargers but have made strides in the BMW ECU world
Dean I have no doubts about the JB product (I believe the internet here LOL) but have never tried them as Ive always gone the ECU fashion, my post was directed to Sylvain the OP who I know. The fastest F10 trapping is Allmotor2000's at around 140 mph. I dont remember what tune he runs but he has a hell of alot of mods to get there. For tune only guys like me and as many as Ive done (30 plus cars with some having more than one) its just what I choose to do (ECU).
Old Mar 29, 2018 | 11:41 PM
  #34
Vic55's Avatar
Administrator
Well thats not good, maybe Akra but its not out yet... hummm.
Or you could do a muffler delete but that might be too loud.
Old Mar 29, 2018 | 11:45 PM
  #35
limeypride's Avatar
2018 AMG E63S
Yup, understood, Vic--I meant only to interject with a bit of firsthand experience.
I tried Dinan once... 2 days later, I stacked my existing JB unit on top of it with a conservative additional boost to restore the power loss. That was the end of my foray into BMW ECU tunes...
Old Mar 30, 2018 | 10:34 AM
  #36
Vic55's Avatar
Administrator
ha (at Dinan gains).... Ive never tried them once and knowing that they are almost too conservative I opted otherwise. But maybe thats how they can back up their "warranty" with low loss ratios due to non aggressive tunes? I dont even want the most aggressive one myself, just that tune that delivers a nice tq/hp curve gain over the usable rpm range.
Sylvain I really can relate to this quote you did over at M5Post as I just picked this up for the summer... what a fun ripping car and I tuned it (GIAC) so its even more "peppy".
The E63 has a nice ride until the road isn’t perfect and then for me it got
Pretty harsh. The 911 GT3 I have rides better on the bumpier roads.
The F90 still rides sporty but more like a 911 which is sporty but still comfortable when the road isn’t freshly paved.
Best analogy is the F90 rides like my 911 GTS and the E63 like a 911 GT3 RS on bumpy roads.
Hope this helps
Old Mar 30, 2018 | 10:57 AM
  #37
Quickburn7's Avatar
Beautiful color combo Vic! I have the same but in yellow. We can do a McDs run
Old Mar 30, 2018 | 11:01 AM
  #38
Vic55's Avatar
Administrator
haaaaaaaaaaaaaaaa
Old Mar 30, 2018 | 11:46 AM
  #39
Quickburn7's Avatar
BTW I got on the power this morning on my F90 M5 and it does feel noticeably faster than the M5....
Old Mar 30, 2018 | 11:52 AM
  #40
Vic55's Avatar
Administrator
which M5? the F10?
Old Mar 30, 2018 | 11:54 AM
  #41
Quickburn7's Avatar
Sorry I meant the E63s feels noticeably faster than the F90. Multi tasking fail
Old Mar 30, 2018 | 11:56 AM
  #42
Vic55's Avatar
Administrator
Oh shi t so you think the tq has to do with it or it really just pulls better??
Dont post this at the M5post, all the fannies will go nuts.
Old Mar 30, 2018 | 12:00 PM
  #43
Quickburn7's Avatar
From what I am feeling.... I think both. The E63 really pushed you in the back of the seat... The M5 a lot less. Not sure why if the reviews and performance times are accurate.
Old Mar 30, 2018 | 12:56 PM
  #44
bobblehead's Avatar
In race mode only or in any modes
Old Mar 30, 2018 | 01:04 PM
  #45
Quickburn7's Avatar
sport plus on both cars. I also feel like the sport plus engine setting on the M5 isn’t as aggressive as in the E63. Hope I am using it correctly
Old Mar 30, 2018 | 01:17 PM
  #46
AMG 17GT's Avatar
R Nine T
so you’ve got a bad sound frequency in exhaust. I would try a short H pipe in between pipes that replaced resonator. H pipes are usually better for drone. X pipe maybe higher frequency.
Old Mar 30, 2018 | 01:32 PM
  #47
thewb's Avatar
SPONSOR
www.wheelsboutique.com
We get our F90 delivered next week. Looking forward to playing with it a bit and we'll let you know what solutions we find for increasing the exhaust note. ANRKY wheels are being built for it as we speak.
View this post on Instagram
Old Mar 30, 2018 | 01:39 PM
  #48
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I'm sure someone has put pressure transducers in the exhaust pipe sections before. Would be interesting to see the running display of the exhaust impulses as the various cylinders fire.
Seems like an interesting math problem to find the right length/shape of pipes to get the desired sound at a problem RPM. Tuning for ideal sound across a range may require active components (doesn't the Mercedes performance exhaust do this?)
If only one had the time . . .
Old Mar 30, 2018 | 01:42 PM
  #49
Vic55's Avatar
Administrator
The resonator removal has not been fruitful even with the F10 M5--(same engine) even with H Pipes... I fear the F90 needs alot of exhaust love yet again compared to the AMG magic.
Old Mar 30, 2018 | 02:12 PM
  #50
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
I heard the DME catless DPs on the F90 the other day and it sounded decent, but I can’t soeak to the drone. Agreed that it’s still not as good as the E63 though....
