UPD W213 E63S AMG High Flow Air Filter Kit
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Drop in high flow air filters are now available. Direct replacement for OEM factory ones.
Deep pleats in the double-layered cotton create a 10-15% increase in filtration surface. This increase allows a greater volume of air to move more freely into your engine cylinders while maintaining superior filtration. Our specially designed cotton filter traps particles as small as 5 microns.Steel wire mesh encases the cotton filter, providing strength and dent resistance so you can be sure your Green High Performance Air Filter will work under the toughest conditions
Other filters use a simple pressure molded injection process to bond the perimeter rubber to the interior components. That method saves manufacturing time, but in the process, a considerable amount of rubber can seep onto the filtering surface. This can restrict airflow as much as 25%. we use a time-consuming and costlier 4 step production process which virtually eliminates seepage and maintains maximum airflow through the filter.
Green Filter USA filters come pre-treated with a specially formulated dirt trapping oil. This oil creates a positive magnetic charge, or ionic bond, with the filters stainless steel mesh. The positive charge attracts the negatively charged dust particles entering the filter, causing them to cling to the steel mesh and allowing the cotton to remain clear for maximum airflow.
Price is $299 and can be purchased through our website or by sending me a PM / Email
http://ultimatepd.com/2018-and-up-me...ir-filter.html
NAV has a set on the way and he regularly tracks his car, so he will post up 1/4 miles results.
I can post dyno results from a NON hear breaker dyno then this thread will take a downward turn. I never quote dyno numbers since each dyno reads different.
View this thread even when we posted dyno numbers they were question so now we don't cater to those request..
https://mbworld.org/forums/w212-amg/...boost-kit.html
Any FI car will benefit from breathing better with a less restrictive filter. OEM filters are about 2 times thicker than the UPD ones.
if u want to see some king of a gains, ask for race logic/draggy times?
that dyno number won’t make your car go fast
Mandarin (08-10-2018)
2021 AMG GLE 63s Coupe AMG GLC 63s Coupe
Seriously anyone with any real automotive tuning background has to be laughing their *** off by this sales pitch...
OEM dry filters for me.
