Drag day with e63s
Old Aug 26, 2018 | 06:54 PM
Mandarin's Avatar
e63s
Drag day with e63s
Hi all. I went for drag racing today to check numbers before tune.
Not bad for 5600lbs sedan. Will see after stage1 tune
Old Aug 26, 2018 | 07:28 PM
Nav's Avatar
Nav
2018 E63S AMG, 2015 ESS Supercharged Lamborghini Huracan, 2016 Mustang GT
Thanks for sharing your results. Good baseline. Which tune are you planning on installing?
Old Aug 26, 2018 | 09:29 PM
tvitarel's Avatar
2019 E63S Estate
5600lbs?
Old Aug 26, 2018 | 09:49 PM
dav461's Avatar
GTR
Originally Posted by tvitarel
5600lbs?
maybe that’s including driver lol
Nav's Avatar
Nav
5600lbs?
Probably meant to say 4600 lbs.
Old Aug 26, 2018 | 09:56 PM
Mandarin's Avatar
e63s
More stupid jokes?
Old Aug 26, 2018 | 09:57 PM
Mandarin's Avatar
e63s
see the picture in the previous message
Old Aug 26, 2018 | 10:02 PM
jkob5's Avatar
19 E63s
I believe that's max weight Car weighs about 4600. Your track might even have a scale
Old Aug 26, 2018 | 10:06 PM
Mandarin's Avatar
e63s
oh yeah, you're right! Nope, it does not have a scale.
Old Aug 26, 2018 | 10:22 PM
dav461's Avatar
GTR
Originally Posted by Mandarin
More stupid jokes?
dont even know what is more stupid, to post picture that proves yourself wrong or to belive that E class can weight 5600lbs
let me think
p.s. Depending on the car spec weight will vary from 1955 to 2048kg
Old Aug 26, 2018 | 10:31 PM
e65's Avatar
e65
2014 E63 S model
Our DA is typically ~3200 on a good day. W213 E63s run low 122-123, sometimes 124 if DA dips under 3k.
I like to know how much difference tune makes and if there is any added benefit to downpipes over the tune.
Old Aug 26, 2018 | 10:33 PM
2012 merc amg's Avatar
2018 S560
So it looks like the way to go is race mode traction control on, that got you a 11.35. Did you do a Race Start where you hold down the brake and gas at the same time? If not those are darn good times and I'd think if you did that you'd be closer to a 11.1. Is the car Stock?
Old Aug 26, 2018 | 11:52 PM
tvitarel's Avatar
2019 E63S Estate
I am curious how this works with track rules. When I used to race at the drag strip in college cars weren't able to run in the 11s without a roll bar and a fire suit. It appears that my local track has lowered the time to 11.5. If cars are faster then 11.5 they want roll bars and a drivers jacket. These cars stock are capable of much faster times then 11.5.
Old Aug 27, 2018 | 12:33 AM
Mandarin's Avatar
e63s
I don't know exactly since that was my 1st drag strip day, but as far as I know, if your car can run faster than 10s you should have a rollbar. But there was a GT-R who was at 9.8 or so and I believe he doesn't have a roll bar. They told me if my car can run faster than 13.99 I have to wear a helmet... nothing else.
That's right, the car is full stock (only spacers and lowering module).
All runs were with launch control start of course.
Yeah, 1st and 4th runs are just in Race mode.
2nd run is RACE + traction was completely off
3rd run is RACE + comfort mode for suspension.
btw MPS4s isn't good with a glue and here is my best 0-60 time even I did 3.33 without glue before.
Here are videos from best run. Same run just was too lazy to edit that...
It was TT class that's why CIvic was there )))))
Old Aug 27, 2018 | 12:51 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Typically down to 11.5 is helmet only, dip under and you needed roll bar (not cage) and drive shaft loop. But now there’s a special class for stock vehicles called AAA class. If you can “convince” the tech that your car is stock, have a helmet, fire jacket, and proof of insurance you can run down to 10.0.
Old Aug 27, 2018 | 01:01 AM
e65's Avatar
e65
2014 E63 S model
the first video it looks like that track is on a downhill slope, is it really downhill or is that an optical illusion.
less than 10 second ET, 140mph or more trap speed they will tell you to slow down. A lot of times they won't say anything
Old Aug 27, 2018 | 01:15 AM
Mandarin's Avatar
e63s
optical illusion, check the Dragy’s screenshot it shows the height
Old Aug 27, 2018 | 01:30 AM
limeypride's Avatar
2018 AMG E63S
NICE!
Time for the tune my friend! As you well know, my "almost identical car" can clobber that time without track prep and on undulating surfaces--your car is merely waiting for more "0111000001101111011101110110010101110010" // and, yes, for the geeks amongst you, there is meaning in that apparently random string of BITS
Regardless, thanks for getting us some numbers and some Dragy comparos which ultimately makes it yet easier still to get numbers others will ack as legitimate!
Old Aug 27, 2018 | 01:38 AM
Nav's Avatar
Nav
This appears to be in Seattle/Kent, WA. DA would have been around 1000 or less. The earlier the run, the better the DA.
Old Aug 27, 2018 | 02:47 AM
e65's Avatar
e65
2014 E63 S model
The da was 671 at 11:53 a.m., the first time slip recorded 11:02 a.m. (edited because initially I read p.m. by accident)
Old Aug 27, 2018 | 10:07 AM
2018 S560
I wonder how much the Race Start is worth. I have not done a race start on my car and not really planning on it as it beats up on the car. I'd think maybe 2/10's maybe 3/10's so without it I guess I'd be like an 11.5 or 11.6. That is still plenty fast enough as far as I'm concerned. Plus I drive with hand controls so I'd have a hard time holding the throttle and the brake at the same time.
Old Aug 27, 2018 | 03:41 PM
limeypride's Avatar
2018 AMG E63S
Based on my tests, race start yields around 0.5s advantage. The launch is just so much more aggressive than merely mashing the throttle.
Embracing my near-infinite generosity, just let me know where you live, we can grab a beer or two and I'll race start your beast repeatedly for you when I'm in Orlando next month
Old Aug 27, 2018 | 04:26 PM
hyperion667's Avatar
2012 CLS63
Surrounded by Honda's!
Old Aug 27, 2018 | 08:31 PM
RobbieRob's Avatar
18'Porsche GT3, 16' Ram 3500 mega diesel,30' Model A Ratrod, 17' E43
2008 cars and newer going 10.00 et or 135 mph and slower does not need a roll bar. New NHRA rules.
Old Aug 27, 2018 | 08:38 PM
Ralcbah's Avatar
2018 E63S
Thx for sharing! Great stock et and super great mph. Looking forward to seeing tuned results...should be pretty awesome.
