W213 headlight abroad
w213
Hi,can somebody give me an advice urgent ,I'm going in the morning abroad and I don't know if I need to stick some deflector on headlight or is some settings to do?Thank you
2020 E 300 Coupe and 2019 GLS 400
Most modern Mercedes cars have an internal flap/lever inside the headlight housing where it changes the beam into a straight cutoff-pattern. I attached the WIS document, it shows the procedure for the w212 ( it might be similar to the 213).
Good luck.
Good luck.
