iPhone Wireless Charging
Old Nov 29, 2018 | 11:53 PM
Gr8 Ape's Avatar
2018 E63S
I recently purchased an iPhone XS. So far I’ve had little success with the NFC charging pad. It either starts to charge and then quits or doesn’t seem to charge at all. Has anyone else had similar problems?
Old Nov 30, 2018 | 01:26 AM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I have also recently purchased a new iPhone Xs. Seems to work fine in my charging pad. Haven't left it in there very long as my commute to work is only 4 miles or so. As far as I know it has continued to charge while on the pad.
One issue we had with my wife's iPhone 8+ is that her case had one of those magnet clips on the back. It didn't like that in the charger. She had to remove the phone from the case to get it to work.
One other issue that might be causing a problem is that both the 8+ and the Xs are a little too long for the space in the charging pad and the phone doesn't sit flat. Sometimes you need to make sure it is in there just right before it starts to charge. If your case is a little oversize, that might be enough to make the charging intermittent as the phone's already too big.
Old Nov 30, 2018 | 03:07 AM
Dagger9903's Avatar
Nissan
Magnets don't work well with the wireless chargers. Must use some sort of induction? I once had a phone with wireless charging and a magnet get SUPER hot while on the charger, probably a bit dangerous.
Old Nov 30, 2018 | 07:23 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
My iPhone XS works perfectly.
Does anyone know if the XS Max and XR fit?
Old Nov 30, 2018 | 07:42 PM
X166's Avatar
2013 GL550
If my phone is near the pad, Apple Pay gets triggered. Anyone have Apple Pay on and still are able to charge? Mine can’t...
Old Nov 30, 2018 | 07:53 PM
Gr8 Ape's Avatar
2018 E63S
My iPhone is currently in a Spigen case, which is supposed to play well with wireless charging. But this makes the phone even larger. I’ll have to check to make sure it’s lying flat.
Old Nov 30, 2018 | 08:09 PM
superswiss's Avatar
2019 C63CS
I don't have my car yet, so I can't give you specific instructions, but you need to turn off NFC in the COMAND system. iOS doesn't support NFC pairing and instead the phone thinks you want to make a payment. This could also be why OP's phone doesn't charge.
Old Dec 1, 2018 | 01:11 PM
kcjonz's Avatar
2017 LR Disco HSE LUX, 2019 E63S, 2019 Sierra AT4
Mine triggers Apple Pay as well; however, it does charge.
My XS Max fits perfectly with the case on, which is great because it would not fit in the M5 I test drove during the long wait.
Old Dec 1, 2018 | 01:19 PM
kcjonz's Avatar
Old Dec 1, 2018 | 02:06 PM
kcjonz's Avatar
The NFC is in the lid of the compartment not in the charging pad, it’s labeled if you look. I just played around and found that if I held my hand over the phone to block the chip it didn’t trigger Apple Pay.
Old Dec 2, 2018 | 01:29 PM
X166's Avatar
2013 GL550
Originally Posted by kcjonz
This solved Apple Pay issue, thanks!
But my phone is still not charging...with and without case...ugh. An early iPhone X. Maybe a known issue?
Old Dec 2, 2018 | 01:31 PM
kcjonz's Avatar
Have you tried it both ways...top in first and bottom in first?
My wife has an X I try hers when she gets home.
Old Dec 2, 2018 | 01:37 PM
X166's Avatar
2013 GL550
I have! And my wife’s new XR even with an insanely thick case had no issues!
I’m going to hard reset my phone later and try it again too.
Old Dec 3, 2018 | 05:19 PM
slappy888's Avatar
Cayenne,E63S
I'm just curious how you fit the Max in there, mine could not even lid it down flat.
Old Dec 3, 2018 | 05:36 PM
kcjonz's Avatar
It lays in there like it’s custom made for it.
Old Dec 3, 2018 | 05:44 PM
slappy888's Avatar
Cayenne,E63S
Do you able to take pic of it? My phone is way too long to fit it in there. BTW, is your car 2019 model?
Old Dec 3, 2018 | 06:15 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
Just triple checked my 2018 10/10/17 build. The iPhone Xs Max will not fit flat even with the cupholder removed.
There is a little lip at the rear of the charging pad that holds up the end of the phone regardless of whether the cupholder is in there or not. The rear of the phone sits about a quarter of an inch above the pad. Seems to work fine though. Probably makes it easier to pick the phone up out of the charging pad area too.
Old Dec 3, 2018 | 06:29 PM
kcjonz's Avatar
Crappy pic cause it’s dark and my iPad has no flash. I couldn’t use my phone for obvious reasons.
Yea this is a MY19
Old Dec 4, 2018 | 05:11 PM
slappy888's Avatar
Cayenne,E63S
That's exactly the same issue as mine, 18 model has a really small pad to charge it (only fit Xs). time for trading for MY19? Lol. I like the new steering wheel, ME function ( Canada don't have it before 19 model's), etc....
Old Dec 4, 2018 | 05:12 PM
slappy888's Avatar
Cayenne,E63S
Yea this is a MY19
Thanks pal, I guess they did not just redesign the steering wheel & vent, too bad for 18 model owner.
Old Dec 4, 2018 | 05:43 PM
izzy63's Avatar
2013 C63
+1 with my leather case from apple it fits perfectly too
izzy63's Avatar
2013 C63
it will fit the XS Max with a case on it, mines is 18.
Old Dec 5, 2018 | 03:17 PM
slappy888's Avatar
Cayenne,E63S
Not for me tho, I will try take a pic from it, was that because the CF console? E634Me seems like have the same issue.
Old Dec 5, 2018 | 03:42 PM
CALBenzo's Avatar
'18 E63S AMG
I would be curious to know. Here is a pic of the mat with my Samsung S9 edge in it which is 6" long. Mine is a late build 18.
Old Dec 5, 2018 | 05:10 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
FWIW, I do have the CF center console.
Initially when I ordered the car, the wireless charging feature was not an option if the CF center console was spec'ed. I was pleasantly surprised to arrive in Germany to pick up the car and discover that it had gotten the refresh which included the wireless charging as well as the Track Pace app and the additional LED lighting colors.
The only thing that it appears I lost out on was that the move of the Cig Lighter plug from the inside of the center console to the front passenger left knee area didn't happen yet on my car. So I only have one 12 VDC plug, which is on the rear center console next to the 120 VAC outlet. Makes powering the radar detector and other front mounted accessories a bit of a pain. But I hard wired the radar detector to the fuse panel near the front passenger right foot area.
