PPF over the front star
Old Jan 1, 2019 | 02:52 PM
tonecas's Avatar
skoda octavia MkII 2.0
Question PPF over the front star
has anyone placed a PPF/clear bra over the front star, where the Distronic sensors are located? I didn't but i have serious doubts of not doing it since this looks like a chip and bug magnet.
Old Jan 1, 2019 | 03:20 PM
Mandarin's Avatar
e63s
I thought about that but did not complete this when I went for full front ppf wrap.
I saw that the shop has covered corners' parking sensors with ppf and I don't have any problems. I assume there shouldn't be any issue with wrapped into ppf Distronic's sensor as well, but I can be wrong.
Better to find this out with local shop simply put a piece of ppf and see what's happened
Old Jan 1, 2019 | 03:54 PM
dav461's Avatar
GTR
I did. all good.
Old Jan 1, 2019 | 04:09 PM
honeybadger15's Avatar
'19 E63s
Mine was covered with PPF, no issues.
Old Jan 1, 2019 | 09:55 PM
MuffinFlavored's Avatar
2018 W213 E 63 S AMG Sedan
What's the benefit of PPF?
Old Jan 2, 2019 | 07:22 AM
tonecas's Avatar
thanks guys!
it protects the surface, in this case the big star, from small chips and bugs that will hit the car at higher speeds. and it makes it more easy to clean the surface
i think i will put the PPF and also cover it with ceramic coating. if the PPF doesn't mess with the sensors then the ceramic probably won't also
Old Oct 15, 2019 | 01:27 PM
Surge's Avatar
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Hmm, my shop, which is highly qualified, said not
to do this. You will have issues with the sensor.
Old Oct 15, 2019 | 01:58 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
I'd be surprised if the PPF bothers the radar that much unless it is tinted or a really thick film. But then again I don't have any experience at 70 GHz.
That said, I have gotten a message or two that the sensor needed cleaning before. Wiped off the bugs next time I filled up and all was OK again.
Old Oct 15, 2019 | 02:20 PM
123's Avatar
123
2018 AMG E63 S
I remember that the front "star" emblem is heated?
Old Oct 15, 2019 | 02:38 PM
Surge's Avatar
I just asked a very reputable firm and they said not to add PPF to the star. They said they tried it and it created problems.
They have no reason to lie, as I'm having both of my cars fully covered, so to add the star would be nothing.
Old Oct 15, 2019 | 03:13 PM
6G Schnell's Avatar
2021 E63S and 2025 GT63
My installer said the same and did three installations for me within a year.
Just checked the EXPEL site and their kit does not have film to cover the star. There must be a valid reason?
https://www.xpel.com/Bumper-Kit-ULTIMATE-PLUS_2209
Everything else in the front is covered.
Old Oct 15, 2019 | 03:23 PM
E634Me's Avatar
Veteran: Army
2018 E63S AMG
The film is pretty easy to remove, right?
Seems it would be a simple thing to apply a test patch of just the star then drive around a bit and try it out. If problems are encountered then remove it and proceed with doing the rest of the car without the star.
The radar wavelength is around 4.2 mm. 3M Scotchgard film is 0.2 mm thick with adhesive per one spec sheet I found. That's ~1/20 of a wavelength so not really a critical multiple. Don't know what effect the adhesive would have on the radio waves but suspect it is minimal. But any time there is a transition between two materials of different dielectric there is a potential for reflection - think light passing from air into water or visa versa. Could be a potential for reflection at the film but if properly applied I'll bet it's minimal.
Googled around on the topic and did see that some manufacturers do have warnings on the use of films over the emblems on cars with radar units behind them. I'll bet is is more CYA than actually a real problem for thin clear films. Tinted and thinker films I could see being an issue.
For example 5G companies trying to use mmwave bands around 28 GHz are struggling with window penetration for office buildings. Most office buildings have thermal tinting films in the dual or triple pane windows and that pretty much kills 28 GHz and even down to 12 GHz (can't put your DirecTV antenna behind an office window with good results).
Unfortunately, the only 3M film I have on hand is some really thick stuff for protecting swing arms or other similar surfaces. If I had some PPF film I'd happily apply it to my star and give it a test and report back.
Old Oct 15, 2019 | 04:41 PM
6G Schnell's Avatar
Exclamation
Solid analysis, agree on all points. And film is easy to peel off.
Let's take a look from the safety point of view: do we want to take chances?
Just recently experienced PRE_SAFE and Brake Assist: while driving on freeway was late to apply the brakes when cars in from of me suddenly stopped. There was a beep, next seat belt tightened, seat bolsters came out and car was already braking... felt really safe. The good news is car stopped safely and no accident.
My 2c: I would rather replace the star if it gets scratched &bugged, than end up in the hospital....
Old Oct 15, 2019 | 04:44 PM
Surge's Avatar
I had a similar experience with PRESAFE when a pedestrian wearing black ran across the highway at night! Belts tightened and car automatically hit the brakes. One of the craziest moments I’ve ever had in almost 30 years of driving.
Not to sound like a Mercedes ad but the car paid for itself in that moment!
I’d rather not risk the system being delayed or not functioning just to have the logo un-damaged by rocks, etc. It’s easy and inexpensive to replace the logo. The radar unit is separate.
Old Oct 16, 2019 | 12:10 PM
Carac's Avatar
2018 E63S Wagon
...3-5mil clear plastic film doesn't block radio waves...there's already a couple mm of hard plastic Mercedes symbol on top of it. FWIW, mine's been wrapped for 18 months and the only thing that's messed with Distronic is when salt got caked on so thick it didn't work one day driving in the winter. It does self checks constantly, if it wasn't working you'd get an error message.
Old Oct 17, 2019 | 09:01 AM
doba_s's Avatar
M3
The Distronic radar sits behind the star and the star is being used as a cover as I understand. Being a plastic piece it passes signals through without any interference. Adding a thin layer of aka plastic PPF film should not create any interference either.
Also I think the Pre-Safe sensors / cameras are in the windshield by the rear view mirror as I had a loaner car without Distronic but it still had Pre-Safe feature.
Old Oct 17, 2019 | 04:07 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
If it’s so easy to peel off, why not just do it and peel it off if it causes problems. I don’t see it being that expensive to add the small easy to reach round circle anyway.
Old Oct 22, 2019 | 02:51 PM
Beast's Avatar
2019 C63S coupe
I had my PPF guy precut it for my GLE63S coupe. I went for a STEK DYNOSHADE tinted PPF and it looks awesome. Does not effect any sensors or distronic
Old Jan 2, 2020 | 11:26 AM
viperamg's Avatar
2019 E63S AMG
I have PPF on entire front of car including star for 9 months without any problems.
Old Jan 2, 2020 | 02:01 PM
6G Schnell's Avatar
Smile
Congrats on your first post!
How about sharing few pics of the beast?
Old Jan 3, 2020 | 11:33 AM
Surge's Avatar
The issue with PPF on the front star is that it will peel off over time. XPEL needs to be adhered to a painted surface. That's why it's not recommended to be applied on metal door sills for example (I asked XPEL about this and they do not advise it).
Old Jan 3, 2020 | 01:08 PM
GermanMIA's Avatar
2020 E63S, 2020 Jeep Wrangler Sport S
I had XPEL applied to the front star as well as the black B and C pillars. My detailer, who is XPEL certified and works only on high end cars (currently has two Speedsters in his shop), told me no issues and he does it all the time.
Old Jan 3, 2020 | 01:22 PM
Surge's Avatar
So is my installer. He has a Huge client base, including A-list celebs, and has zero reason not to cover the star. I had my G wagon and AMG GT fully wrapped. He refused to do the star, saying it was a bad idea. It can also affect Distronic and Collision Assist. I would not do it!
Old Jan 3, 2020 | 01:46 PM
b0rderman's Avatar
E63S Wagon
How much is a replacement lens for the star anyway, that is if it gets beat up over time?
Old Jan 3, 2020 | 01:50 PM
Surge's Avatar
It depends on the model but it’s not expensive. It can be replaced by itself.
