Auto Folding Mirrors Stopped Working
2. I occasionally get the annoying woman telling me that I have exceeded the speed limit--it is clearly the Mercedes Nav or computer system (not Waze or my Escort Max 360ci). I go into "system" / menu options / voice alerts to make sure voice alerts are off and the voice alert option is set to off--I will then turn it on and then off again and that typically works but not always. (Thankfully she has been quiet for a while.) --I have gone into the Nav menu and nothing there seems to apply..
3. My voice control is spotty at best and finding Nav locations is horrible.
4. Fast-forwarding and pausing music on a thumb drive requires you to go into the menu and select "control"--this is ridiculous--there should be a dedicated button for these functions.
The infotainment and control through the computer is a nightmare in this car. I am pretty tech savvy but this car frustrates the hell out of me--the infotainment system really needs an overhaul.
All that said, I love the performance, the interior and looks. It is a great car but Mercedes could do a lot better regarding ride comfort options in order to reduce harshness when on pot-holed horrible winter beaten roads and the aforementioned infotainment system. [NOTE: Since setting tire pressures to 40 front 35 back the ride is significantly better.].
I do not believe I changed any settings, and in fact I double checked to make sure that feature was still turned on.
Any suggestions on a fix?
Well it was worth a try. I think I may just do a reset on the vehicle and see if that works. (Earlier this week my GLE would not start CarPlay no matter what I did. I did a reset on it and it worked but it also erased all my media stuff
I did this too and they worked. Although I’ve had to do it two more times since the first time. Any ideas why they might keep hanging up?
I have a 2020 c43 and my auto folding mirrors just stopped working . I searched and found this answer. Just did it following these directions and the problem is fixed.
Thank you so much. It's very nice to have this forum where members can help each other's out!
A year ago I had my main unit replaced so that the android car would work(i had a Mitsubishi unit and now I have Panasonic- which was coded to my car options) but until yesterday everything worked without any problems. I did a factory reset and still nothing.
any suggestion?
Anyway, the fix for me, as it seems for others, was to hit the button to fold and unfold the mirrors. After I did that, everything is working as it should.
Unfortunately using the menu options didn't work for me, but manually folding and unfolding using the button on the driver's door did.
No idea why my wing mirrors stopped automatically folding when locking the car!
Interestingly it coincided with the nav (not on / never used) telling me randomly that the end of the traffic jam was ahead - scared the bejeezus out of me as I have NEVER heard the car talk before.
Gremlins.
